Changing a tranny/ getting it running
Old Sep 12, 2008 | 10:07 AM
Kevin M's Avatar
Well I went and got myself a new used transmission for my 85 4runner. The reverse gear went out in mine so I picked up a used tranny for $250. It is a 5 speed W56. Anyways with the help of my dad and Fairchild AFB hobby shop Lift I am going to replace the broken one. Besides a clutch kit is there anything else I should replace when I do this?
Also I will be replacing the front springs (the Passenger side is sagging a inch lower then the drivers side), U joints front and back, new diff oil, oil change, and plugs/ wires. My 4 runner has basicly been sitting for 4 years but still starts ups and runs, is there anything else I should do?
Thanks, Kevin
Old Sep 12, 2008 | 11:23 AM
83's Avatar
83
Shifter base and seat wouldn't be a bad idea. Real cheap and helpful.
Old Sep 12, 2008 | 12:21 PM
toyminator2000's Avatar
x2
Also, grease up everything with a zirc fitting. If the u-joints aren't bad there is no need to replace them. Toyota U-joints are pretty stout. Just grease them up and see how it does. I would use factory Toyota tune up stuff (plugs, wires, cap, rotor, etc.).
I got a set of 3" lift springs that will fit that truck. PM me if you are interested.
Old Sep 12, 2008 | 12:55 PM
Kevin M's Avatar
When I got back from the desert 6 years ago I put a 4 inch lift on the truck, 33 BFG Muds, 4.88 gears with a detriot in the rear. The lift kit worked great for a while but then I noticed the passenger side was sagging. The company that sold it to me (NWOR) dicked around with me for a while and then when they finally did send me the paper work to get repalcement springs I had no way of getting the springs off to mesure them. Anyways I got the new springs for the front. I am pretty sure the U joints in the rear are bad, there is a whinning/ screaching noise from the rear end so I am hoping that is what it is.
Old Sep 16, 2008 | 07:44 AM
Kevin M's Avatar
Originally Posted by toyminator2000
x2
OK, I will come clean, I do not know that much about cars and trucks, besides the basics I am somewhat lost. What are the cap's and rotors?
Thank you,
Kevin
Old Sep 16, 2008 | 12:27 PM
83's Avatar
83
Distributer cap and the rotor is inside of the cap, it's what points at the spark plug wires & fires them. Go to Toyota & ask for plugs, wires, cap & rotor and they'll give you what you need. Look at your engine & you'll see where they go. The Toyota ones even have the spark plug wires labled 1 through 4 for your convenience. If you can't figure out how to get them in after that with some kind of repair manual, you shouldn't be doing this yourself.
Old Sep 16, 2008 | 01:32 PM
Kevin M's Avatar
Thanks, I figured they had something to do with the distributer but I was not sure, and yes I do know where it is and have taken it apart before.
Thanks,
Kevin
Old Sep 17, 2008 | 08:10 AM
83's Avatar
83
Yup, good. It's really pretty damn simple. Good luck! It aughta run pretty nice after all that, if everything's adjusted right.
ashersullivan88yota
Jan 18, 2022 05:37 PM
icentropy
Sep 16, 2020 02:47 PM
smiley52
Jul 11, 2015 05:16 AM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
