Center Support Bearing Removal
I just wanted to give thanks for Steve at South Bay Driveline for helping me solve a irritating problem that I was having. After lifting my '84 Extended Cab I was experiencing some "spine tingling" vibrations coming from underneath the truck. After climbing under the truck, I found that the center support bearing was completely worn out and the rear half of the driveshaft's pinion angle sucked. Once I discovered this, I weighed the options and found that I could either replace the center support bearing and have the same thing happen down the road, or I could cut it all out and replace it with a one piece shaft. After doing some looking on the net, I stumbled across this article and it grabbed my attention (http://www.4x4wire.com/toyota/tech/driveshaft/).
After reading the entire article a couple of things stuck out. This shaft was, in essence, a chevy shaft built to fit onto our Toyota trucks. This shaft was completely ready to go and outfitted with Dana/Spicer u-joints which means they are strong, as well as easy and cheap to replace if needed. I was sold, so I contacted Steve and all he required was the flange-to-flange measurements in order to get the shaft built. I provided him with these numbers and he custom built and shipped the shaft the same day. When I recieved the shaft, it was noticably lighter and beefier, so I put it in and haven't looked back.
I just thought I would give Steve some "props" since he treated me really well and the price was more than reasonable. That's just my two cents.
And......That's it.....
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Sep 4, 2015 09:27 AM
terminator
Jul 27, 2015 07:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
