cant find vacuum leak!
Hey ya'll! i have an 84 carburated with a weber 38 on top. My truck flooded out on a trail and dieseled a little after shut down. since then my truck barely holds idle. I have to keep the high idle cam engaged in order for it to run or it will slowly start to bog down, then shut off. Also when i stab the gas the engine stays at a higher rev for about 2 seconds before it slowly comes back to idle. Also if i pump my brakes to at a stop, to create vacuum it will bog the idle and shut down...THE IDLE USED TO INCREASE IF I DID THIS BEFORE. This is what makes me think vacuum. My truck is totally desmogged, the only lines i use are from carb to distributor, then distributor to vacuum advance. I have no idea what it is. The carb was jetted and tuned perfect for the last 2 months since my rebuild. Took a trip to the woods, engine flooded, now barely holds idle.
Best way to find a vacuum leak is get a cheapie little propane bottle with a tip...open it up...point tip all around suspected areas while running. When it revs up a little bit....you have found your leak.
This was the first thing I changed were the seals on the adapter plates. Today after work I had no clutch until I pumped it about 20 times
TokyoD23
Jul 12, 2015 06:01 AM
Avenged
Jul 9, 2015 07:55 AM
