Can I swap these tranys ?
Old Feb 21, 2011 | 03:49 AM
2003mikem's Avatar
I have a 1985 4runner 4 cylinder EFI. I blow up the tranny this morning.
I have a spare one from a 1986/87 4x4 truck that is carbureted. Can I swap them out ?
Old Feb 21, 2011 | 04:26 AM
waskillywabbit's Avatar
Compatible to the motor, yes. What you have is probably top shift. The other forward shift. You'll have to swap tranny and tcase.
:wabbit2:
Old Feb 21, 2011 | 04:33 AM
2003mikem's Avatar
Both have the shifter on the top ? is there much of a difference where they are ?
The spare one was rebuilt by Toyota.
Will the drive shafts be the same length? Or will I need to change them.
I lost reverse. Or I should say is clunks and pops out of gear ?
Old Feb 21, 2011 | 04:51 AM
Top shift tranny has 5 spd shifter - one shifter hole on tranny
Forward shift tranny has 5 spd shifter AND tcase shifter on the tranny - two shift holes on tranny
Tcases for top shift have short shift forks as the tcase shifter is on TOP of the tcase, thus "top shift"
Tcases for forward shift have long shift forks as the tcase shifter is on top of the tranny, thus FORWARD of the tcase.
The existing shifter hole cut in your tranny tunnel for the tcase will be 6" off.
You can convert top shift to forward shift tcase and vice versa.
:wabbit2:
Old Feb 21, 2011 | 05:09 AM
windedwalrus's Avatar
yes the drive shafts are the same
2003mikem's Avatar
i I think I understand ? by chance do you have pics?
Old Feb 21, 2011 | 05:16 AM
sorry i don't. just look at the shifters are they closer togeather on one trans? they might be the same and you don't have to worry about the top shift forward shift thing. even if they are different they are still interchangable. the only problem you might have is the shifter hole on the trans tunnel minght be off.
Old Feb 21, 2011 | 05:21 AM
here's the best example i have. the middel shifter is from my old forward shift case. i had to change it out late one night and didn't have time to make a cover plate for the hole. the rear shifter is where a top shift case sits. i only have one t-case the truck has not been doubled yet.
Old Feb 21, 2011 | 05:23 AM
2003mikem's Avatar
So worse case is I will have to cut the tunnel and make a new cover correct ?
Also are the gears in the tranny the same ?
Old Feb 21, 2011 | 05:25 AM
yeah that's all. the gears are the same.
Old Feb 21, 2011 | 06:01 AM
You need to understand that a forward shift tranny and top shift tranny are NOT interchangeable in and of themselves, unless you swap the tcase that goes with them as well.
Will they both work behind a 22R/RE, yes.
With a little searching you should be able to find pictures.
:wabbit2:
Old Feb 21, 2011 | 06:12 AM
2003mikem's Avatar
I will swap the tranny and t case together.
Old Feb 21, 2011 | 09:32 AM
2003mikem's Avatar
What gear lube do I use ? and best to use ?
Also dose the tranny and t case share the lube or do they both get filled separately ?
Old Feb 21, 2011 | 09:56 AM
2003mikem's Avatar
how do i tell what my spar tranny is ?
Old Feb 21, 2011 | 10:02 AM
:wabbit2:
Any gear oil will work. Local auto parts. Amsoil. Redline. Tons of options.
Please do some searching man, this ain't hard, but you don't seem to be helping yourself at all.
:wabbit2:
Old Feb 21, 2011 | 11:36 AM
blake.nemitz's Avatar
different fill for the t case on the back
Old Feb 21, 2011 | 04:50 PM
dropzone's Avatar
Fossilized
and the various stickies on this forum would have yielded this transmission ID info:
http://www.4x4wire.com/toyota/faq/parts/
http://www.marlincrawler.com/transmi...built-complete
Old Feb 21, 2011 | 07:27 PM
:wabbit2:
but you can put a top shift t-case on a forward shift trans. just not the other way around.
Old Feb 21, 2011 | 07:42 PM
top shift trans and t-case
forward shift trans
Old Feb 22, 2011 | 04:21 AM
2003mikem's Avatar
my runner had the top shift and i put the forward shift trans in
the forward shift trans seems to beefer ?
