Can I drive with this unknown part broken
Old Jan 27, 2007 | 03:13 PM
paxil4x4's Avatar
Drama Queen/Banned
While changing out my valve cover gasket I found some sort of emissions device that attaches to the lower part of the air cleaner assy broken in two.
The only way to describe this part is it has a hose going out the top going into the air cleaner and another going back into the intake manifold and it looks like a black air chamber of some sort. It has a directional arrow on it with the word UP
It's also located next to the battery. It looks like someone repaired it once already since it has ? of JB Weld and bondo on it. I plan to order a new one, but can I still drive my truck? I noticed when I started the truck it was loud, but went away as it warmed up.
My truck is an 85 carb 4x4
Old Jan 27, 2007 | 05:05 PM
myyota's Avatar
It sounds like your talking about the resonator, you can drive with out it, but it will be a little loud with out it. i would try a wrecking yard for this part, it will be cheaper than the dealer.
Old Jan 28, 2007 | 03:15 PM
paxil4x4's Avatar
Drama Queen/Banned
Found one at pick and pull for $3.00 that was mint, and right after I put it in. The Toyota gods were not on my side because I broke my A/C bezel with my finger while installing an A/C switch. Pick and pull had none of those laying around.
voiddweller
19
May 2, 2016 09:10 PM
Tommy T.
Jul 5, 2015 07:48 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
yamaha73
Jun 18, 2015 06:19 PM
infinityisfive
Jun 16, 2015 06:51 PM
