Cab Swap
Old Aug 19, 2008 | 05:35 AM
corvettelvr73's Avatar
Cab Swap
I have a 85 EFI that i fliped and I bought a 86 carb truck to switchj the cabs on but the 86 is not efi and I was woundering what i have to change to get it to work with a efi truck. Thanks
Old Aug 19, 2008 | 05:39 AM
ozziesironmanoffroad's Avatar
now you're in the same boat i was. what sucks is the wiring harness looks about the same, but its not. you have to take the dash off the old truck, take the wiring harness out, put it in the new cab, put the new dash in, (or keep the old one, i chose to keep my old VIN plate). now i dunno bout you, but i had to cut the gear shift hole a little bit in order for the 4wd stick to clear properly. but really other than that, it should be a piece of cake. i mean i did mine without taking the intake manifold off to run the harness through... yeah i had small hands then lol. good luck!
Old Aug 20, 2008 | 08:50 AM
that blows japanese weiner
Old Aug 21, 2008 | 05:28 AM
what else will i have to look forward?
Old Aug 21, 2008 | 03:50 PM
drew303's Avatar
Thats about it. besides reinstalling the ECU into the new cab (kinda obvious). The only differences is wiring. Swap the cluster out of the junk cab to.
Otherwise the cabs are identical, well, almost identical Im not sure what changes might of been made between 85 and 86 but I think they changed the dash lines in 87. dont quote me on that.
Old Aug 23, 2008 | 12:37 PM
the interior is the same but my 85 is extra cab and the 86 is not so i have to relocate the back 2 body mounts forward 6 inchs but thats not a problem. thanks. post pics if anybody has some. thanks
young buck
18
Aug 27, 2018 02:40 PM
coleypull15
Nov 3, 2015 07:41 AM
Robojd1
23
Jul 21, 2015 01:43 PM
mtb_taco
Jul 15, 2015 08:36 AM
elwood73
Jul 5, 2015 07:07 AM
