A/C compressor & Bracket
Old Aug 11, 2006 | 09:46 AM
Carolina Cummins's Avatar
I have a 1984 22r pickup and I'm installing a/c from a donor truck that's missing the compressor and motor bracket. Would the bracket from a 22re be the same? I also need a compressor.
Old Aug 11, 2006 | 12:35 PM
ToyotaGuru's Avatar
Parts
There are 2 brackets. But I was sure the compressors had the same
mounting. I have about 6 compressors and brackets.
Which style ac lines do you have? Do they come in from the side
of the compressor or the front?
Old Aug 11, 2006 | 02:46 PM
I don't have either the bracket or compressor for comparison. I was told only the 22r bracket and compressor would work on my 22r, the 22re is differnt. I looked up the compressors on the internet for the 22re and 22r and gave two different compressors.
I'm trying to find a picture of a 22r compressor so I'll know what to buy.
Thanks for your response and I'm interested in your brackets and compressors if you want to sell.
Old Aug 11, 2006 | 08:01 PM
mtndave's Avatar
When I took the factory A/C off my 87 22R 2wd extra cab and swapped it into a 85 22RE 4X4 standard cab, everything bolted into place. However, I used the 87 22R block for the 85 EFI but I think the blocks are identical. The 85 had aftermarket A/C which used a different compressor bracket, not as solid as the OEM bracket. Hope that helps
mwisham
May 26, 2021 02:51 PM
coryc85
Dec 5, 2015 08:42 AM
JUICE222
Oct 13, 2015 08:50 AM
Ktm526
Oct 7, 2015 05:14 AM
gp66
Sep 7, 2015 08:29 AM
