Bypassed ignition coil kill switch, now no start
Old Feb 26, 2013 | 04:53 PM
yotasonaplane's Avatar
So just bought this stock 85 extended cab a few months back and its ran great. The only thing not stock is a kill switch wired into the ignition coil that has worked great. I use it when I park in the city or bad neighborhood and the truck turns over but wont fire cause theres no spark, right. So I used it the other day, came back and flipped the switch back to normal and it did just that, turned but wouldnt fire. Jiggled the toggle switch a bit and the wires connected to it and got it to start. Then it kept cutting out on the way home and even had to pull over and jiggle the wires again.
So anyways I was thinking bad connection or bad switch. The switch was was installed in-line coming off the negative coil terminal (terminal closest to the cab right?). So I bypassed it, cut the wires and crimped them together.
Now it still turns over but wont fire. Tested the coil terminals and get zero resistance between them. So now im really confused.
What did I do wrong?
If my splice job was bad why am I getting zero resistance?
Was my coil bad all along?
Or was the switch acting as the ground or something?
Any input welcome.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
msane99
Jul 11, 2015 08:08 PM
skoti89
Jul 8, 2015 12:05 AM
colinmil
Jul 6, 2015 04:03 PM
Vargntucson
Jul 4, 2015 12:15 PM
