Burning oil but how?
Old Sep 7, 2009 | 05:42 PM
-=j0nnyr0773n=-'s Avatar
I recently replaced all gaskets and seals on my 20r engine. Got the head resurfaced and cleaned and replaced all of the valve stem seals.
I now lose about a quart of oil every 50 miles or so. There's not a constant stream of blue smoke coming out, but when I gas it hard a few times you can see a small cloud of blue smoke.
When I am downshifting and coming to a stop you can see blue smoke coming out as well.
I did a compression test and here's the numbers.
Cylinder 1: 135
Cylinder 2: 135
Cylinder 3: 120
Cylinder 4: 130
When I put a small amount of oil down cylinder #3 the compression jumps up to 130.
I was thinking I had a cracked ring on 3 but when I check the spark plugs, none of them have any sign of burning any oil. They are a light tanish color like they should be.
Any thoughts on what else I can check? There's no leaks whatsoever.
Old Sep 7, 2009 | 06:27 PM
vital22re's Avatar
totally a bro
its gonna be worse after the valve stem seals. The new found compressions gotta go some where and your rings are the weekest link. Sounds like its time for a bottom end rebuild.
Blamalam
Mar 12, 2022 07:34 AM
TJWilly
Jul 31, 2015 02:05 PM
calderp
Jul 27, 2015 09:58 AM
HookahRoo
Jul 20, 2015 07:06 PM
rushw
Jul 18, 2015 01:46 PM
