Broken Wheel Lug
Old Oct 3, 2007 | 08:00 AM
Malczuk4runner's Avatar
Broken Wheel Lug
i have a 1988 4runner with a 85 SAS. the Passenger side front wheel has a lug broken off, i dont know how it got like that, i bought it broken. Does anyone know if i have to replace the whole knuckle/axle shaft peice, or do the studs unscrew and i can just replace it. What is required to fix this?
Old Oct 3, 2007 | 08:23 AM
frodin1's Avatar
Pound it out and get a new one from your local autoparts store.
Old Oct 3, 2007 | 08:37 AM
rdlsz24's Avatar
Time to get out the BFH!
Rob
Old Oct 3, 2007 | 08:39 AM
04 Rocko Taco's Avatar
Bang the old one out through the back of the wheel hub, then put the new one in, stack a ton of washers on it, and threa da lug nut onto the end till it makes contact with the washers, then hit it with an impact gun, it will tighten doen the lug nut against the washers, and pull the wheel stud into the hub. They are an interference fit, which means they have to be pressured into the hole, and there is no room BEHIND to get a BFH in there, thats why you use the air gun trick. Good luck.
Old Oct 3, 2007 | 09:28 AM
G's 84 Runner's Avatar
Time for the BFH and pin to hammer em out. I would be caution with the autozone brand, when I went through this exercise with mine, their brand wasn't wide enough, or long enough. Not sure if the 84 and 85 wheel studs are the same diameter. Thats my $.02
I went to the dealer for my replacements. $5.00 each.
Old Oct 3, 2007 | 09:35 AM
I got mine at NAPA, they were perfect, I had to replace 20 of them. lol.
ViperTT
Aug 14, 2015 05:27 AM
ToyoToler
Aug 8, 2015 08:43 AM
cgilley
Jul 25, 2015 10:55 PM
rushw
Jul 18, 2015 01:46 PM
jon.r
Jul 11, 2015 03:34 PM
