Brake Upgrade - extended studs
Alright, the plan is to upgrade to the vented rotors... I picked up a set of 81 LC rotors and 95 runner calipers. However, I'm running 1.5" wheel spacers on each side, and the spacers don't grab much of the stock wheel bolts. Does anybody know if there are Wheel bolts that would be compatible with this setup? I found that ARP make some for Lexus, that would appear to work, although I thought I would check with the experts first. Here's the ARP catalog, if that helps: http://www.arp-bolts.com/Catalog/Catalog.html
Thanks
Thanks
you should be able to go to a NAPA / (any parts store where you are) and get extended studs in the proper thread pitch. I work with lugs and studs all day long and don't really see the need to go with ARP hardware...
Jun 1, 2021 01:51 PM
94ofCanada
Aug 14, 2015 06:37 AM
CanRunner
Jul 20, 2015 01:29 PM
