brake/charge light on with high idle
Old Jan 19, 2011 | 08:39 AM
zdchapman's Avatar
Smile brake/charge light on with high idle
brake/charge light on + high Idle . .. Hello ,im new here and if anyone could give me advice would be great ! My trucks brake/charge lights just both came on and my truck idled very high @ 2000 rpm or so . i know that usually means your alternator is (out) so i took it to get tested and it was BAD - installed the new one and things worked great after , two weeks later both lights are back on and truck is high idling again . . . got the new alternator tested twice and its good - installed new RED TOP , battery terminals ,cleaned ground and checked all fuses and still the same issue .
maybe a short ?? bad connection ?? not to sure seeing as the truck was running great prior . . . only has 51,000 original miles (1984 EX CAB) 4wd . . . . .any help would be great ! thanks much
Old Jan 19, 2011 | 04:23 PM
zdchapman's Avatar
just installed a new voltage regulator and things are running great again !
Old Jan 19, 2011 | 05:36 PM
RogueYota's Avatar
The EXACT SAME THING happened to me...turned out my battery was low on water.
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
