blowing back threw the carb
Old Jun 9, 2006 | 08:57 AM
Carolina_yota's Avatar
what could make it blow back trew the carb on a 22r? Ive done checked the timing with a timing light, changed fuel filters, plugs, plug wires, and checked for vac. leaks. ive done tried every thing i know to try.
Old Jun 9, 2006 | 09:40 PM
kyle_22r's Avatar
adjust your valves? intake valves that are too tight won't close all the way and will cause a backfire.
Old Jun 10, 2006 | 07:40 AM
manyodas88's Avatar
good luck to you carolina yota! i had been fighting this same issue for the last 4 months with no luck. i finally decided my time wasn't worth it and put a for sale sign in it and sold it in 2 hours. hopefully the valve adjustment will work for you if it does i will relay the info to the guy that bought mine. have a great day!
Old Jun 10, 2006 | 07:54 AM
rdharper's Avatar
Compression test?
Old Jun 10, 2006 | 08:01 AM
4runnermt's Avatar
Have you had the distributer out? I have seen warped distributer shafts cause some problems like this before, but never on a toyota. Maybe worth a look?
Old Jun 10, 2006 | 01:39 PM
Superflex84's Avatar
is this on shutdown or when accelerating?
if its under throttle, then the above responses would be my first guess.
it its when you shut off the ignition then it could be carbon buildup, fast idle...
one of my 22r carbs was sucking air through the throttle plate shaft... the bushing was wiped out and it was dieseling pretty bad till I pulled it off and trashed it for a Weber 380
Old Jun 12, 2006 | 03:51 AM
yea i pulled the distributer out and the distributer was fine. im ganna adjust the valves today. I gatta get it ready to drive down to the truck show in myrtle beach.
MO transplant
Apr 23, 2023 11:58 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Yota.Jay
Jul 23, 2015 08:08 PM
dpridgeon3
Jul 9, 2015 01:18 PM
elwood73
Jul 5, 2015 07:07 AM
