Blinker/hazard lights stopped working - Diagnostic
Old Jan 4, 2011 | 12:32 PM
mikesta's Avatar
I searched in this forum and didn't find but 5 entries for Hazard. So here we go.
1985 Toyota 22re
Hazards and blinkers - kaput - no workie
Checked fuse under glove box - good (there are 2 of them there)
Checked Flasher - blown, Replaced flasher, still no love, tested flasher in my other 85 truck, tested good.
I've read on other years that it could be the column. I've checked the fuses by the battery box, they look ok.
Any other thoughts? Thanks again!
Old Jan 4, 2011 | 01:04 PM
xxxtreme22r's Avatar
does your horn work?
Old Jan 4, 2011 | 01:18 PM
mikesta's Avatar
Holy Crap, no it doesn't! Recommendation?
Old Jan 4, 2011 | 01:23 PM
last time I had that happen it was the fuse under the hood. FUse looked good but when I replaced it they all worked.
Old Jan 4, 2011 | 02:15 PM
mikesta's Avatar
I'm going with your gut and will let you know! Thanks TRE.... Yes it was blown. Now I have horn, but still no flashers
Any other suggestions?
Old Jan 4, 2011 | 02:20 PM
mikesta's Avatar
Old Jan 4, 2011 | 03:15 PM
nope, almost positive that it's that fuse under the hood.
Old Jan 4, 2011 | 03:18 PM
mikesta's Avatar
The fuse was blown, I put a good fuse in there and now the horn works, but I cannot get any love from the flashers, blinkers/hazards. That fuse under the hood is now perfect.
Old Jan 4, 2011 | 03:21 PM
not sure what else to do on that one then. I would think if were in the switch at least the hazards would work since that's not a part of the switch.
Old Jan 4, 2011 | 03:35 PM
mikesta's Avatar
I need to go buy a tester and test some wires. Heading to the autopart store now, I'll make sure this tester isn't set to Ohms! Learned that mistake last time
Old Jan 4, 2011 | 04:00 PM
JoshToy84's Avatar
Check the flasher relay..it might've gone out.
Old Jan 5, 2011 | 11:23 AM
mikesta's Avatar
It is the blinker switch, there is a short in it $50 later. Anyone have one of these? Its on Page BE-6 of the factory service manual.
Old Jan 5, 2011 | 11:31 AM
I think 4crawler has a repair page for those switches, I might be wrong though. Might just need to be cleaned out.
http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
It's related to the headlight/highbeam problems, but might be able to help ya out.
Old Mar 3, 2015 | 08:23 PM
sea dawg's Avatar
I'm trying to get my horn working. I have flashers, but no horn?? Not familiar with fuse under the hood in an '85, and can't find anything on it in the FSM. I know I could put in an auxiliary horn button, but I'd really rather get it working on the steering wheel.
Thanks
Old Mar 5, 2015 | 06:20 AM
thefishguy77's Avatar
First check to see if the horn is in place and that the wires are hooked up. I had that problem on my 93. . Horn was there but wires were missing.
zd92655
Mar 6, 2022 12:58 PM
gillesdetrail
Nov 19, 2019 12:56 PM
aciorba23
Jun 29, 2015 04:18 PM
cchinny
Jun 25, 2015 08:11 PM
gog1968
Jun 22, 2015 05:55 AM
