Black Smoke
Old Dec 7, 2008 | 01:16 PM
D-Man's Avatar
Black Smoke
I'm having problems with blowing black smoke on a '86 22R Pickup....I installed a new carb from Kragen Auto Parts, I haven't adjusted any of the air/fuel mixture screws as of yet thinking that everything would already be set. Engine has a 154,XXX miles on it. I bought the pickup from a guy in Pennsylvania, and now it's in California with me. Could there be any other reason for it to be blowing so much black smoke!!!!
Darryl
Old Dec 7, 2008 | 02:13 PM
85toy's Avatar
well i hope your not planning on smoging it because that aint gonna happen in cali. but it sounds like your running rich which means your gonna have to tune the carb.
Old Dec 7, 2008 | 03:57 PM
abecedarian's Avatar
Sounds like you're running way rich to me also. Could be a few things like the float level too high, the idle mix is too rich or the jets are the wrong size or even the choke not pulling off. Could also be your timing isn't set correctly.
Old Dec 7, 2008 | 05:01 PM
D-Man's Avatar
Hey, Thanks for the reply's......I do plan on smoging it here in Cali which shouldn't be a problem. 85toy, why do you fill that I won't be able to get it smogged here in Cali? Anyway, I'll check my adjustment on the air/fuel mixture according to specs. Again, THX
Darryl
Old Dec 8, 2008 | 12:07 PM
85toy's Avatar
i have a feeling that you wont be able to in cali unless ALL the original lines and hoses are used. now i dont know what brand youg to but i know that people who use weber carbs cant smog in cali.
Old Dec 8, 2008 | 10:23 PM
XtraSlow_XtraCab's Avatar
Actually it all depends on where the pickup truck was originally SOLD in the United States. If it was sold in California, its a California emissions truck. Anywhere else, and it is labeled as Federal. The smog equipment was simply a little less hefty and I don't believe an air injection pump was required on Federal trucks.
So if that Toyota was originally sold (back in 1986 or 1987) outside of California, it can only be tested as a federal truck... even if the testing is IN California.
Now as far as MODIFYING a vehicle... well then I do believe all modifications must not conflict with Californian Vehicle Regulations if the vehicle is to be registered in California. Its ok to replace any dried out hoses, just re-route them as per the factory service manual emissions diagram.
puddlepirate
Jul 30, 2016 06:29 PM
dzldust
7
Oct 6, 2015 05:39 AM
dbollier123
Sep 29, 2015 05:23 PM
whiteyota93
Sep 29, 2015 02:31 PM
charlie_fong
Sep 27, 2015 10:06 PM
