bad mileage = motor running bad?
Old Feb 21, 2010 | 10:59 AM
84toyota4x4extcab's Avatar
Okay so heres the deal i recently swapped in a 22re into my 84 yota. When the motor was in the 87 it would about 20-25 mpg since i put it in the 84 im getting about 8-9 mpg which makes no sense at all. the truck has a 4:10 gear ration and im only running 31" tires so i doubt thats the problem the motor does not burn oil and the only thing it really needs is an alignment, any ideas?
Old Feb 21, 2010 | 01:09 PM
laskt9's Avatar
not having it aligned can kill your gas mileage. what size tires were on the 87?
Old Feb 21, 2010 | 03:17 PM
the 87 had 31s as well but the tires were not as aggressive as the ones i have on my truck now
Old Feb 21, 2010 | 03:35 PM
laskt9's Avatar
aggressive tires will kill gas mileage too get it aligned and see if it improves
Old Feb 21, 2010 | 03:41 PM
myyota's Avatar
When you swapped motors did you put the injectors from the 84 engine into the 87 engine ?, if not that could be your problem. In 87 toyota changed the injectors (i can`t remember exactly what they did), i know 85-86 injectors are the same, but not sure about the 84 injectors. So try putting the 84 injectors into the new motor and see what happens.
Old Feb 22, 2010 | 09:43 AM
im bringing the truck to get it aligned some time this week and ill check the injectors
Old Mar 3, 2010 | 09:42 AM
i havnt brought the truck in yet due to work but i was wondering if the gears would be the problem i have a set of 4:30 gears that came out of the 87 would these give me better mileage?
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
karbin
Jul 5, 2015 11:37 PM
toyoda8488
Jul 5, 2015 10:18 PM
