axle cleanup!
Old Mar 17, 2009 | 03:39 PM
Ron's 85's Avatar
axle cleanup!
finally got some time in the shop. I started the hysteer process while i wait for trail gear to send the goods. I removed the stock stabilizer bracket and third link. looks alot cleaner down there!!!!!!
Attached Thumbnails axle cleanup!-winter-09-047.jpg   axle cleanup!-winter-09-057.jpg   axle cleanup!-winter-09-061.jpg
Old Mar 17, 2009 | 03:46 PM
dropzone's Avatar
Fossilized
looks good, you are gonna love the difference between the push-pull and the IFS steering box.
what front DS are you using?
Old Mar 17, 2009 | 03:53 PM
Ron's 85's Avatar
Ds???
Old Mar 17, 2009 | 08:41 PM
Ron's 85's Avatar
Originally Posted by ron's 85
ds???
stock!
Old Mar 17, 2009 | 08:45 PM
Plumbrbob's Avatar
after my high steer install i could turn in a raduis that was never imagined before!
Old Mar 17, 2009 | 08:52 PM
Ron's 85's Avatar
I dont think i will gain much turn radius. my 35 x 12.5's rub on my leafs at full cock already. should a buy wheel spacers? i think it would be cool to ditch the fatty 12.5's for some 35x 10.5 swampers!
Old Mar 17, 2009 | 09:00 PM
Plumbrbob's Avatar
I run 36 x 12.5 TSL's with a 2.75 BS no problems with no tire to leaf rubbage. had problems in the rear with frame rubbage at full stuff had to bolt up some 1.5" wheel spacers.
swampers are cool!
Old Mar 17, 2009 | 09:02 PM
Plumbrbob's Avatar
Oh yea I also remember i was running a 4" Pro comp lift with the origanal push/pull steering and I welded a drop in the drag link for my steering correction. What a PITA
Old Mar 17, 2009 | 09:12 PM
Ron's 85's Avatar
my tg parts should be here 2morrow. i need to find a steering box quick. do i have to have a steering stabilizer or should i be fine without it?
Old Mar 17, 2009 | 09:19 PM
algranger's Avatar
Steering stabilizer is usually personal preference. I wouldnt leave home without mine.
algranger's Avatar
Oh bellingham eh? You should come wheelig with me and plumbrbob some time
Old Mar 17, 2009 | 10:50 PM
Plumbrbob's Avatar
they always say if you plan on driving over 40 or someting, some guys dont run them someguys stand by them I run with one. you'll be fine without one though
Old Mar 17, 2009 | 10:55 PM
BigWavePaul's Avatar
Thumbs up Fresh
It looks like Toyota just dropped it off at your shop. That's a great job! You'll be ready for anything with that setup. Good luck with your high steer install.
Old Mar 18, 2009 | 07:21 AM
Ron's 85's Avatar
i have heard of Reiter pit. is that near you guys. i am going to run a stabilizer, i removed the bracket from the axle very clean so i can reuse it up top on the frame. Walker valley in skagit is pretty sick!
Old Mar 18, 2009 | 07:35 AM
Plumbrbob's Avatar
bellingham! man what was I thinking LOL bellvue I think . Reiter is about 1 1/2 hr from me it is near gold bar. Yea Walker valley! I have heard of that place and I want to check it out I am assuming that is close to you?
Old Mar 18, 2009 | 08:43 AM
algranger's Avatar
Oh damn i was thinking Bellevue too. I will have to check google maps for Bellingham. Reiter is fun it's about 2 hours from me. We are heading to Tuhuya this Saturday it's near Belfair i think... hell i'll be honest i dont know the area at all i'm new here
Edit: Oh yeah you're way up there. Reiter pit is about the same drive south for you as it is north for me. Tuhuya is quite a drive for you. My guess would be 2.5 hours
Old Mar 18, 2009 | 10:06 AM
Ron's 85's Avatar
that is a drive all right. walker valley is about 40 minutes away and that seems far. i usually explore the logging roads in my area off the mt. baker highway. there aren't many crazy spots, but there are some great elevated veiwpoints and camping.
Old Mar 18, 2009 | 10:10 AM
algranger's Avatar
Yeah i've been meaning to get on some of the local logging roads. I just hope i dont accidentally end up on Ft. Lewis property. Nobody here lives real close to me so i usually end up driving 2 hours to go wheelin but i dont mind
Old Mar 18, 2009 | 03:18 PM
oldgold3vze's Avatar
Just a suggestion when it comes time to mount your IFS box. Mount that puppy as far forward as you can. I run RUF and I had to cut out my radiator support to slam the box forward. It keeps the drag link and tie rod from rubbing. Have fun!
Old Mar 18, 2009 | 03:34 PM
Ron's 85's Avatar
thanks for the tip. my present should be here any time!
