awesome 84 p/u and 85 runner find
Old Apr 23, 2010 | 03:52 AM
RBX's Avatar
RBX
there IS a block off plate on my EFI 22re
Old Apr 23, 2010 | 07:51 AM
tyler_1990's Avatar
Thank ye for checkin and lettin me know
Old Apr 24, 2010 | 06:59 PM
PuddleJumper's Avatar
What a find!! Score at $500 for both! Even $500 only for the 'Runner would've been sweet!
Did you say the 4Runner is pretty much rust free??? I HATE metal cancer .
Congrats and welcome from one newbi to another....
Hey! We gotta start sometime.
Old Apr 24, 2010 | 07:07 PM
tyler_1990's Avatar
gotta q are the injectors located in the cylinder head or is there a fuel rail that the injectors connect to and goes into the plenum
Old Apr 25, 2010 | 10:18 AM
  #25
abeD85flatbed's Avatar
injectors are in the lower intake manifold/plenum and are fed by a fuelrail running down the middle of the intake. The fuel pump block off plate will be an issue. the neck for the thermostat housing on the 22re runs right where the mechanical fuel pump mounts for the 22r. Either swap the block off plate between the heads along with everything else, or buy one from an auto parts store. The domestic plates can be had for a few dollars and by reaming the holes out a little, will fit the toyota head just fine. I've ran one like this for years.
Old Apr 25, 2010 | 02:46 PM
  #26
myyota's Avatar
You can use the stock computer, the computer for the transmission is located below the dash in front of the shifter, just unplug it, all you will need to do to get it to start once everything is swapped it to jumper the neutral saftey switch wires.
Old Apr 26, 2010 | 12:13 PM
  #27
84toyota4x4extcab's Avatar
for the 5 speed to work your eithe gunna have to switch the computers and block off all the plug ins you dont need or jumper the neutral switch
Old Apr 29, 2010 | 11:23 AM
  #28
tyler_1990's Avatar
Is there anyone in the central pa are that can help with a 85 efi engine harness and vacuum lines I'm in need of assistance since I'm picking up on what someone left off. If you can please let me know. Pics of your rigs connectors and plugs and vac lines will he'lp a lot also
Old Apr 29, 2010 | 04:57 PM
  #29
tyler_1990's Avatar
Its an 85 22re
Team420
Jan 12, 2021 04:57 PM
vasinvictor
Jan 20, 2016 12:39 PM
83flatt
Jul 2, 2015 10:30 AM
ACZR
Jun 23, 2015 07:55 PM
