Any ways to get the RPM's down?
I love my 85 pickup, but I hate that it is turning close to 3500 RPM at 75 MPH. I know, the truck was geared to be the most efficient at 55 MPH which is closer to 2500 RPM. I would like it to be closer to that RPM at today's speeds. I have 205/75-14's which is a 26 inch tire.
Did Toyota ever make gears for these trucks that were higher than 4.10's, or did they make a trans with a better OD? They're only a 15% overdrive (.851) which doesn't help enough. The tallest tire I could find in a 14 was a 27 inch, which would help but not a whole lot. Truck has basically new tires on it as well, so I would hate to change them.
It still gets 29 running at 75 MPH, but I hate that I'm revving the piss out of it to do so.
Anyone have any info?
Thanks!
Thanks!
Toyota fitted a 5 lug 8" axle for 4 speed 2wd trucks that came with 3.07 gears (G662). This would net 2352 RPM's @ 70MPH with your current tire/rim combo. Only issue is it may be a dog off the line and require smoking the clutch from a standstill on hilly terrain.
BTW, the axle needs to come from an 84-88 model. Older 8" diffs have shorter axle shaft widths and while newer ones have longer axle shafts.
22RE's like revs!
Sounds like you have a two wheel drive, so it's doesn't exactly translate, but I don't think any of my 4x4's could have maintained 70mph at under 2.5k rpms. No matter the gearing or tire size, there is just no power down there.
I'm on 35's and 5.29s, I pull around 19.5 out of a tank at 70mph (corrected). If you're getting 29 out of yours that sounds like a happy engine and I wouldn't worry about the revs.
22RE's like revs!
2wd I bet it would be easy to find a aftermarket overdrive unit.
29mpg I would be happy with 15mpg
I am pretty sure I never had a 22R series engine in a 4x4 over 60 mph
Celica`s would be a different story I plead the 5th.
Chris Cook
Mar 1, 2016 10:39 AM
ZRTALPHA1
Feb 21, 2016 12:12 PM
Stump1883
Sep 4, 2002 09:16 PM
