Another Gas Mileage question
Old Apr 12, 2007 | 08:22 AM
bob200587's Avatar
Originally Posted by chopitrakeit
to chime in with maybe relavent info, with my 1989 3.0 and the 35-12.50 MTRS, running 4.10 gears I have found that the odometer reads 8.1 km for 10 km travelled. Filled up, drove approx 80 km hiway, running around 100-110 km/hr (actual), filled up again. Calculated 13.6 l/100km, or 20 mpg (imp)
got me confused, I don't know the difference in an Imp. gal and a US gal, but it's gotta be quite a bit, because there's no way you could EVER get 20 US mpg with a 3.0, 35s, and 4.10s....If I saw it in person, I still don't think I could believe it.
I don't' see how you drive that thing, It must be so incredibly slow......
Old Apr 12, 2007 | 08:24 AM
bob200587's Avatar
Originally Posted by Mark in MD
Convenience. If you're often driving off road, like daily, it's just more convenient. If I was taking a trip though, I'd unlock them.
I think you'd have to be wheeling a lot every day to make it worth while......it takes like 20 seconds to get out and lock them. Definatley unlock them if you aren't going off road or expecting hazardous weather.
Old Apr 12, 2007 | 09:03 AM
LUV24BY's Avatar
Here is a interesting tid bit of information I found online. This is the specs for the 1987 model year. It supports the 17.2 gallons capacity others claim. Has anyone else made the switch to the SR5 instrument cluster and found that the gas gauge doesn't reflect the correct level of the actual fuel level?
1st Generation Info & Specifications
Here is the actual Specifications for the 1987 model year:
John
Old Apr 12, 2007 | 11:14 AM
bob200587's Avatar
The gas gauge on any vehicle is usually inaccurate to some degree. Mine doesn't even work anymore. On my Ford it still works, but I still keep track of miles rather than just watchint the gauge.
Where did you find the info on the truck? that looks like a sales brochure from way back when.
Old Apr 12, 2007 | 11:36 AM
  #25
LUV24BY's Avatar
Yeah, there is always a factor of not 'right on the money' - the image is from the site I found on 1st Gen Toyota's.
John
Old Apr 27, 2007 | 10:51 AM
  #26
Ksane's Avatar
Ok, well if you had stock 235s, or whatever they were, and you go up to 31's, take the miles you went on the tank and add 10% of the amount to it. say you went 200 miles on the tank, add 20 miles to that, THEN divide by the gallons. And that will give you an accurate reading.
I've got an 87' 4Runner with 250K miles & 33x12.50's and use this formula also. Using the "adding 10%" I get 19.13 mpg. Without adding the 10% it's 17-something mpg. After I added BG's 44K I went up just under a full 2 mpg, that stuff's great. It's only a 4 cyl 5 spd and it's got bigger tires and is 20 yrs old, so considering all that I'm pretty pleased with the gas mileage.
shisha1999
Sep 21, 2015 08:22 PM
pyramid
Jul 30, 2015 10:05 AM
nonstop
Jul 24, 2015 06:29 PM
daddio
Jul 18, 2015 10:20 AM
Cplmike
Jul 8, 2015 08:47 PM
