algranger's 1984 Pickup Build-Up Thread
Old Jan 2, 2009 | 04:05 PM
  #81
hillbillydeelux's Avatar
Originally Posted by algranger
before and after
i just pounded that in and covered it in bondo and it turned out nice.
how did you manage to mess up the sheet metal on the bed where the back is going to be joined? more importantly how did you fix that? the bed i bobbed was kinda hard cause nothing lined up good and it is really hard to fill a 1/4 inch gap in sheet metal.
good job im givin you props.
Old Jan 2, 2009 | 10:09 PM
  #82
algranger's Avatar
thanks i was pleased and surprised with my work
haha well i was using like an 8" long sawzall blade for wood/metal i was cutting that corner where the bed floor meets the side and the blade punched through and tore the hell outta that. i just pounded it in like half an inch and bought a gallon of bondo
i had the 1/4" gap issue too, i broke the sheilding gas off of my welding rods and welded them in the gap with the mig.
one way i found to improve the gap issue was to tack it together in 4 spots, then run a sawzall blade along the whole cut and it will take out any spot where the metal touches itself, then cut the tack welds and retack it a little closer. keep doing this till its all flush. i just lost paitence and filled it with rods.
Old Jan 2, 2009 | 10:17 PM
  #83
algranger's Avatar
im starting the lift right now everyone as soon as i drop the gas tank im gonna cut the rearend off so stay tuned.
Originally Posted by dub84
i need a bed like that...i think mines off a 2wd cuz it dont match
this is a 2wd bed too there were different ones some had the outter lip and some, like this one, had the inner. i got the 2wd parts truck for free! all it needed was a timing set and new valves so it was my donor motor, red body parts, interior and seats.
i picked up my 84 toyota dlx for 400 bucks it even had new tires...it burns oil but other than that im happy...you have a nice truck to start out with...put an lcengineering motor in it lol
nice! this one had new tires too i paid 700 for this and its base model, rusted out, and had a bad motor so id say 400 is a pretty damn good deal. theres no way im puttin an lc motor in it i just spent 3 paychecks to get a late model 22r in there so i can efi it i have dreamt the lc dream though
Old Jan 2, 2009 | 10:21 PM
  #84
hmm i bobbed two beds they both didnt line up as well as yours looked, prolly cause the 1st one was on a ranger and i used the plasma cutter
Old Jan 2, 2009 | 10:25 PM
  #85
algranger's Avatar
hah nice i tried to use the torch but the paint caught fire you can see here
Old Jan 2, 2009 | 10:30 PM
  #86
algranger's Avatar
oh and dub84, your truck looks freakishly close to my first truck
i like your style!
Old Jan 4, 2009 | 10:58 PM
  #87
algranger's Avatar
starting the chev 63" swap heres before i started cutting it apart
as i lowered the axle i realized i would need to lower the brake line as well so i made a little drop bracket
sheetmetal prototype hangers recive approval
after approval the real deal is created and welded on
how it sits now
Old Jan 5, 2009 | 10:03 AM
  #88
scuba's Avatar
These pictures dont do it justice
Old Jan 6, 2009 | 03:51 PM
  #89
algranger's Avatar
yeah its hard to tell that its even changed.
heres the final stance its still hard to tell without the bed on but you can tell it lifted
hey the snowflakes or whatever those are look like pentagons isnt that exciting?
Old Jan 6, 2009 | 03:54 PM
  #90
algranger's Avatar
oh btw i lost my brakes today so it looks like ive got my next project lined up. theres a little jet stream of brake fluid coming from one of the lines next to the gas tank it shoots about 5' high i must have cracked a line when i was workin on the lift
Old Jan 7, 2009 | 05:22 PM
  #91
TrikeKid's Avatar
I would throw something on the front of the hangers to make the transition from the frame rail a little smoother, so you don't end up being caught on them or even worse tweaking one while wheeling.
Old Jan 7, 2009 | 08:18 PM
  #92
algranger's Avatar
yeah good idea i'll do that.
got the bed on. turns out 12" was more than i wanted to go (i had to cut the frame too) but overall i'm pleased with the outcome.
we've got some massive flooding here so my yard is a prime playspot. i'm gettin a decent little mud run goin over in the southwest corner
Old Jan 7, 2009 | 09:09 PM
  #93
toyospearo's Avatar
I think it is perfect! Perfect length.
Looks great.
It will look REALLY good with bigger meats on there.
Old Jan 7, 2009 | 09:14 PM
  #94
algranger's Avatar
thanks. i'm gonna put mixed rear packs up front and then get some meats on there.
ive decided i do like the 12" bob i cut the frame flush with the hangers and the bed is about that too
Old Jan 12, 2009 | 08:52 PM
  #95
algranger's Avatar
finished the front tonight all but the driveshaft
Before: (the dog disapproves)
Inspection process:
Approval is given:
Flat stock leafs
Old Jan 12, 2009 | 09:25 PM
  #96
scuba's Avatar
*borat voice* AAA VEEEEDDDYYY NICEEE !!!
Old Jan 12, 2009 | 10:52 PM
  #97
stagger_lee's Avatar
oh AL that sits perfect man! Looks like it was supposed to be. Nice job! Not too high, perfect.
Whole thing looks phenomenal.
Old Jan 12, 2009 | 11:04 PM
  #98
Johannes's Avatar
x2 for the vvvveeerrrrry niiiiiiice
Old Jan 12, 2009 | 11:49 PM
  #99
algranger's Avatar
thanks man im really happy with the stance.
Old Jan 13, 2009 | 07:12 AM
  #100
toyospearo's Avatar
Very nice!!!
