Aisin Manual Hubs - Need Part #'s
Old Apr 4, 2010 | 09:03 AM
redwolf3's Avatar
Hey Guys-
I did some searching and found some posts listing part numbers that look right, but every time I do a look-up through the dealer, the parts show up for a completely different vehicle, so I wanted to run this past you guys.
I am look for the part numbers for the following parts for an '85 4-Runner (4wd obviously):
- Front Inner Hub Seals
- Aisin Manual Locking Hubs Gasket (between rolling hub and manual locking hub housing)
- Aisin Manual Locking Hubs Gasket (Between selector face and housing)
- Aisin Manual Locking Hub Selector Seal
I think I have part numbers for a couple:
- Aisin Manual Locking Hub Gaskets (between rolling hub and manual locking hub housing) - #43422-60010
- Aisin Manual Locking Hubs Gasket (Between selector face and housing) - #43531-60010
But when I search for these, they both show up as being for '93 to '98 Tacomas, but they may be the right parts.
I know I can pick these up online through several places, but I'm trying to get this thing back together ASAP. I can order these online from my local dealer and have them delivered the same day, but I just need the part numbers (because they don't have part numbers online for these older vehicles).
Any help is greatly appreciated.
Old Apr 4, 2010 | 09:20 AM
waskillywabbit's Avatar
Dealer has all the part numbers. If they tell you different they are lying.
Old Apr 4, 2010 | 09:48 AM
redwolf3's Avatar
Wab-
I'm sure they do, but if I order online from them, the cost is 2 - 3x less. Example: went to order a "Valve Grind Gasket Kit". In store, $260... online $112. Parts ship from the same store, are the exact same parts... but cheaper online for some strange reason.
The catch with their online ordering is you need to use their search feature, or have the part number in hand. I guess worst case I can go into the store, get the part numbers, and then go home and order online, but I was hoping to skip the first step if possible.
Old Apr 4, 2010 | 10:13 AM
xxxtreme22r's Avatar
Reference http://www.toyotapartszone.com/onlin...reName=MCD016C
43422 GASKET, FRONT AXLE OUTER SHAFT FLANGE **422-60010 1983.08-1986.03 LN6#, RN6# 2 $0.75
43506 BODY & BRAKE SUB-ASSY, AUTO LOCKING HUB (NOT AVAILABLE) Replaced by: **506-35H10 **506-35020 1985.08-986.06 RN6#.. 5F.. SR5 2
43506 BODY & BRAKE SUB-ASSY, AUTO LOCKING HUB (NOT AVAILABLE) Replaced by: **506-35H01 **506-60011 1984.03-1985.08 RN6#.. SR5 2
43508 BODY SUB-ASSY, FREE WHEEL HUB Replaced by: **508-35050 **508-35010 1985.08-1989.03 LN66, RN6#, VZN6# 2 $85.12
43509 COVER SUB-ASSY, FREE WHEEL HUB (NOT AVAILABLE) **509-35012 1983.08-1985.08 LN65, RN6# 2
43509 COVER SUB-ASSY, FREE WHEEL HUB **509-35030 1985.08-1989.03 LN66, RN6#, VZN6# 2 $165.65
43530 HUB ASSY, FREE WHEEL Replaced by: **530-39035 **530-39017 1983.08-1985.08 LN65, RN6# 2 $305.21
43531 GASKET, FREE WHEEL HUB **531-60010 1983.08-1989.03 LN6#, RN6#, VZN6# 1 $1.84
43531 GASKET, FREE WHEEL HUB Manufacture notes: W/AUTOMATIC LOCKING HUB **531-60020 1983.08-1989.03 RN6#.. 5F.. SR5 1 $2.28
43532 RING, FREE WHEEL HUB **532-60010 1983.08-1989.03 LN6#, RN6#, VZN6# 1 $2.93
43533A NUT, AUTOMATIC LOCKING HUB LOCK **533-60010 1983.08-1989.03 RN6#.. 5F.. SR5 2 $34.15
43534 DRUM, AUTOMATIC LOCKING HUB BRAKE (NOT AVAILABLE) Replaced by: **506-35H10 **534-35010 (IRRG) 1985.08-1986.06 RN6#..5F..SR5 1
43535A COVER, AUTOMATIC LOCKING HUB (NOT AVAILABLE) **535-35010 1983.08-1989.03 RN6#.. 5F.. SR5 1
BOLT, W/WASHER Replaced by: **641-80616 **119-06024 1 $0.53
BOLT, W/WASHER (NOT AVAILABLE) **119-08435 1
BOLT, W/WASHER **119-08466 1 $1.11
SCREW **149-50023 1 $0.64
SCREW, CROSSRECESS C **151-50007 1 $0.70
SCREW, W/WASHER **159-60210 1 $1.19
Old Apr 4, 2010 | 10:26 AM
redwolf3's Avatar
xxxtreme22r-
Wow! Sweet, thank you very much for all that info. That's exactly what I was looking for.
I'm also going to bookmark this website, looks like a great research tool for future "odd-ball" Toyota parts, of which my 4-Runner seems to have plenty of.
Old Apr 4, 2010 | 10:27 AM
make sure I used the right vehicle info though. might want to plug in your vin to be sure. Prices there are pretty good too. unfortunately the gaskets you need are dealer only noone seems to have them and they are needed in order to replace rotors. Which I am in the middle of doing as we speak lol.
Old Feb 14, 2012 | 10:23 AM
pholife's Avatar
pn 43422-60010 is no longer available.
is 43422-60020...the equivalent....
thanks yota part mastas!
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Road Bull
Oct 10, 2015 04:55 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
ItsJustD
Jul 7, 2015 07:49 AM
colinmil
Jul 6, 2015 04:03 PM
