a340h problems: no 3rd gear
Old Sep 28, 2007 | 11:55 AM
patallen's Avatar
I posted this a while back, but it seems it moved to the wrong forum...
https://www.yotatech.com/forums/f2/1...rd-gear-60129/
just want to make sure it reaches all the good guys
thanks.
Old Sep 28, 2007 | 01:39 PM
4runnerx3's Avatar
First thing to do is unplug the ECT unit, it's under the radio.
and do a manual shift. L is first, 2 is third and D is overdrive. You loose 2nd gear because you killed 1 & 2 shift solenoids. This test will let you know if you have a solenoid problem. You also are disengaging the lockup solenoid, #3.
Old Oct 1, 2007 | 05:18 AM
patallen's Avatar
thanks for the reply, but if you follow my uper post, i made all these test a while ago, i am now digging into the valve body since everything else has been made
-new ect
-new solenoids
-all gears are present when ect is disconnected so no burnt bands or clutches
thanks.
smthwsn357
May 1, 2024 07:28 AM
crammit442
7
Nov 29, 2017 12:30 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
HollieJayyy
Aug 9, 2015 07:59 AM
