YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   a340h problems: no 3rd gear (https://www.yotatech.com/forums/f115/a340h-problems-no-3rd-gear-125822/)
patallen 09-28-2007 11:55 AM
I posted this a while back, but it seems it moved to the wrong forum...
https://www.yotatech.com/forums/f2/1...rd-gear-60129/
just want to make sure it reaches all the good guys ;)
thanks.
4runnerx3 09-28-2007 01:39 PM
First thing to do is unplug the ECT unit, it's under the radio.
http://i22.photobucket.com/albums/b3...4runner464.jpg
and do a manual shift. L is first, 2 is third and D is overdrive. You loose 2nd gear because you killed 1 & 2 shift solenoids. This test will let you know if you have a solenoid problem. You also are disengaging the lockup solenoid, #3.
patallen 10-01-2007 05:18 AM
thanks for the reply, but if you follow my uper post, i made all these test a while ago, i am now digging into the valve body since everything else has been made
-new ect
-new solenoids
-all gears are present when ect is disconnected so no burnt bands or clutches
thanks.
