89 4Runner SAS - Passenger Side Wheel Hub/Caliper destroyed
Old Jun 13, 2017 | 11:37 AM
Zach Brown's Avatar
Question 89 4Runner SAS - Passenger Side Wheel Hub/Caliper destroyed
Alright, so my buddy has an 89 Toyota 4runner with an 84 solid axle swap up front and dual transfer case setup with 4.7 upgraded gears. He had been at an offroading event, and on his way home [highway driving, 60mph] his RF wheel hub caught on fire. I was wondering what would cause this to happen?? -- if you take a look at the pictures, the caliper is missing a good chunk of metal.
Master cylinder was recently replaced and front calipers weren't bled.......**against my advice**
Attached Thumbnails 89 4Runner SAS - Passenger Side Wheel Hub/Caliper destroyed-20170612_174630.jpg   89 4Runner SAS - Passenger Side Wheel Hub/Caliper destroyed-20170612_174830.jpg   89 4Runner SAS - Passenger Side Wheel Hub/Caliper destroyed-20170612_174619.jpg   89 4Runner SAS - Passenger Side Wheel Hub/Caliper destroyed-20170612_232407.jpg   89 4Runner SAS - Passenger Side Wheel Hub/Caliper destroyed-20170612_174622.jpg
Old Jun 13, 2017 | 11:48 AM
millball's Avatar
Looks like plain old wheel bearing failure may have cascaded into other issues. The brake pads don't seem to be excessively burnt.
You don't show the hub and rotor. It's my guess from what you have shown that the brakes were not the issue that got the ball rolling.
Old Jun 13, 2017 | 11:59 AM
Zach Brown's Avatar
Any suggestions on how to avoid this sort of failure in the future?
Thanks for the quick response @millball
Old Jun 13, 2017 | 12:07 PM
millball's Avatar
Stuff happens
Clean bearings, packed with hi-temp wheel bearing grease, then correctly adjusted. The other side may need attention too.
Can't believe that there wasn't warning noise or steering/braking abnormalities before total meltdown.
From the looks of your pics, that spindle may be scrap. Still like to see an image or two of the hub and rotor too.
Old Jun 13, 2017 | 12:19 PM
Zach Brown's Avatar
Old Jun 13, 2017 | 12:24 PM
Zach Brown's Avatar
Bearing just needs some grease right? Lol
Old Jun 13, 2017 | 12:26 PM
dropzone's Avatar
Fossilized
stay out of water, do proper maintenance
From the looks of your pics, that spindle may be scrap. .
I bet it was wobbly and loud prior to grenading
I agree about the spindle being recycle material
Old Jun 13, 2017 | 12:29 PM
millball's Avatar
The caliper, rotor, and hub don't look like they got super hot, so I stick with 'not a brake problem'.
The spindle and axle stub sure don't look good.
Old Jun 13, 2017 | 01:52 PM
Zach Brown's Avatar
Take a closer look at the caliper picture.. It's missing a good chunk of metal
Old Jun 13, 2017 | 02:38 PM
millball's Avatar
Sure, the rotor ground it up after everything got sloppy. It's ruined, but it's probably not what started the problem.
