85 short block in an 88?
Old Sep 20, 2009 | 12:51 PM
dstn2bdoa's Avatar
Is there any reason I can't use a 22r short block from an 85 in my 87 EFI runner?
Thanks
Old Sep 20, 2009 | 06:42 PM
myyota's Avatar
The blocks should be the same, as far as i know.
Old Sep 21, 2009 | 09:33 AM
dstn2bdoa's Avatar
Thanks, anyone else before I buy this thing.
Old Sep 21, 2009 | 06:15 PM
mistreatedtoys's Avatar
The short blocks are different I think they changed mid 85 but not sure. The way to tell the early 22r from the later is on the drivers side just behind the engine mount is a machined flat spot with tabs on either side. This was where the oil port fro the turbo engines was machined out. The deck height is different on the older one and while everything bolts up the timing chain will be like 1/2 tooth off and never run quite right.
Corvoid
Jul 4, 2021 11:51 PM
dumpster84
Apr 30, 2016 06:03 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
jon.r
Jul 11, 2015 03:34 PM
Coreyr384
Jul 10, 2015 11:13 AM
