85 PU straight front axle
Old Apr 8, 2008 | 03:26 PM
doylelane's Avatar
I have an 85 regular cab PU with a straight front axle. The axle leaks at the heim joints. My brother has his own mechanic shop and has rebuilt several of these to get them to stop leaking with no results. Does anyone know of another vehicle that I could get a straight axle out of and mount into my truck with little modification.
Andy
Old Apr 8, 2008 | 03:39 PM
hurley842002's Avatar
Unless you are going full width 3/4 or 1 tons (which would require probably more modification that what you are probably looking for) you really couldn't find anything to match a toyota axle as far as size and strength.
Old Apr 8, 2008 | 03:47 PM
Spinnbait's Avatar
Andy
at the heim joints???
Old Apr 8, 2008 | 03:53 PM
Elvota's Avatar
Yes... were is it leaking exactly?
If you mean at the knuckles... and leaking gear oil... then it's the internal axle seal that has failed.
Marlin makes a much better one than OEM, but if the housing is bent or knuckles are aligned improperly then that seal will fail quickly over and over again.
Old Apr 8, 2008 | 04:00 PM
fastkevman's Avatar
Aren't Dana 44's just as strong and about the same width?
Old Apr 8, 2008 | 05:28 PM
85toy's Avatar
they are not the same width.
Old Apr 8, 2008 | 06:13 PM
They are not the same width. Closest thing would be maybe a scout II dana 44
Old Apr 8, 2008 | 06:14 PM
I don't doubt that 44's are probably as strong but with a ring gear of 8.75" its not much bigger than a toyota 8" and you have to think about bolt pattern. Just my opinion
Old Apr 9, 2008 | 12:34 PM
85toy's Avatar
i wouldnt bother changeing out toyota axles unless your going 1 ton.
Old Apr 9, 2008 | 12:57 PM
camo31_10.50's Avatar
screw it....go full width...Dana 60's front and rear...with a 14in lift kit...and some 54x19.50 Super Swamper BOGGERS!!...with a built 426 hemi...lol..nah..im just kiddng...please dont do that..(but it would be awesome) go to a junkyard and get another axle...thats what i would do...but..idk if it would be as good..might be worse than yours...just rebuild it...and if you do serious offroading..then regear...go longs..hy-steer...all that jazz when u do the rebuild...save you time on having to do it later..lol
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
yourrealdad
Jul 21, 2015 11:13 AM
