85 leaf spring swap
Old Apr 26, 2008 | 07:14 AM
baseballchamp157's Avatar
85 leaf spring swap HURRY
Ok I just bought a 3in lift from rough country. For my 85 yota pickup. well im having problems with the leaf springs. The front bolts of the front leaf springs were easy to get off but the back is different. I cant get the beck bolt of the front leafs to come out. is this how i do it or am i doin it wrong? I need help. im about to go CRAZY
Old Apr 26, 2008 | 07:29 AM
4Crawler's Avatar
By "the beck bolt of the front leafs", are you referring to one of the nut on the spring shackles? If so, not uncommon for the upper shackle pin to get sort of stuck in the shackle bushings through the frame. I usually need to get the spring end loose then use a rubber mallet on the threaded end and then twist and pull on the shackle while hitting the other end to pull it out. With the shackles I run now, I can put a long handled box wrench on the head of the bolt and twist/pull on the bolt that way:
Old Apr 26, 2008 | 07:33 AM
Yea the one on the shackles. So do I pull both of the bolts out?
Old Apr 26, 2008 | 07:53 AM
Thanks man. Ive got it to work now. Thats what i needed!
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
shisha1999
Sep 21, 2015 08:22 PM
boogiewoogie
Jul 24, 2015 05:10 AM
Nickdigg
Jul 7, 2015 06:04 AM
