85 Front Clip
Old May 17, 2007 | 09:11 AM
Magoo's Avatar
85 Front Clip
im fixin to buy an 85 that got smacked in the front right.
is everything bolt-on up there or am i gonna have to weld.
basically the metal that is behind the grill,that the fenders and the grill bolt to.
Old May 17, 2007 | 09:57 AM
Sonofmayhem's Avatar
Pretty much, unless something is crunched. most of it is bolt on, you can buy most of it from Partstrain.com
Old May 17, 2007 | 04:26 PM
myyota's Avatar
The inner fender and radiator support are welded in, it those are damaged you will need to cut the old ones out and weld in new ones, if they can`t be straightened.
Old May 17, 2007 | 06:32 PM
fustercluck's Avatar
Drill the spot welds out with a pilot point 3/8ths bit. Drill through both pieces of metal with the pilot part of the bit and just past the first sheet of metal with the shoulder part of the bit. Get them all, and the pieces of metal will separate as if they were never welded.
Re-weld with a mig at low temp directly in the hole created by the pilot point while the two pieces are clamped together. With a little practice, you can reproduce the spot weld look and function. It goes faster than it sounds....
Old May 18, 2007 | 07:58 AM
LUV24BY's Avatar
I had someone turn left in front of me and took out the right front portion of my 4 Runner. I just hooked some Chain up to my wifes suburban, dropped the Runner in 4 LO and backed up slowly until it was mostly straightened out. I then bought Fiberglass replacement Hood & Fenders from Toyota Fiberglass. I went this route because most aftermarket crap sheet metal doesn't align up right, so I went custom pieces! Then - got the headlight buckets, radiator support, bumper, grill and marker lights from Car parts Wholesale. If you visit HERE - you can see the damage my Runner had, then go to the next page to see the new parts being put on!
Hope this helps! PM me if you want any help!
John
Old May 21, 2007 | 08:27 AM
Magoo's Avatar
my damage is worse than yours
the battery is smashed into the inner fender,and its bent up pretty good,and it seems the fender ripped away from the inner fender.
im gonna try to straighten it.it doesnt have to be perfect.just work.
Old May 21, 2007 | 08:40 AM
Woah you are in co? well then, welcome
There are alot of toyota junkyards in denver and one in colorado springs
Old May 21, 2007 | 09:49 AM
Magoo's Avatar
yip ole crawlarado.
lots a bone yards but i have minimal welding access.plus ive never really fooled with body work.but i can prolly figure it out
Old May 24, 2007 | 06:52 PM
john4wd's Avatar
This is what happened to me in 1998 (My old 87 Toy 4x4 truck)...It was raining and I T-Boned a girl in an intersection after she hydoplaned into it and the whole clip was toast...I had a grille guard on and it and it pushed everything back...
If I didn't have the grille guard on it would have only took out bumper and brackets and apren...It was totaled, but got it back plus $2500 from insurance...Went to salave yard and got a front clip off of a unrusted 4-Runner clip ($260) and drilled out spot welds on cab horns and inner fender attached to cab and then bolted the repainted to match rest of truck 4-runner clip to truck...The last bolt at top of inner fender (Right side) to cab was a bitch it way above the blower assembly very tight...After I was done everybody I asked couldn't tell it wasn't origanal...One bad thing, I had to cut the factory wiring bundle going into engine compartment by battery and rewire and solder and shrink wrapped them all back together...
If you go this route, label all the wires one at a time as you cut them...I got them all right first time...Guy who bought my truck back in 2000 is still drving it ;} A 2WD clip will work too...Just some things are a little different on the inner fender...
I was lucky and they had just got in 2 rear end weaked 4x4 trucks (Front ends undamaged)...And I got everything (less than 1/4 cost of new) to rebuild it all at once...The 4-runner was just a completely stripped out body laying on the ground...I got firewall forward to radiator supports ...I had to remove new clip (from firewall and cab horns) the same way I removed damaged old clip...Good Luck...
John...
Ps. Radiator support if new comes in 4 pieces (Dealer told me) and have to be welded together and dealer quoted me $1000 for parts and it to be welded together......Radiator support and inner fenders are welded together too...So I went with the used front clip instead...Cheap and easy and fun to do...
Old May 25, 2007 | 01:56 AM
85TurboRunner's Avatar
just a heads up, you don't need to cut the wires, they unplug from the fuse box under the hood. all the harness comes out without cutting.
Old May 25, 2007 | 08:42 AM
Magoo's Avatar
well i will be embarking on this mission soon,like this weekend.id like to fix it cheap and easy but i think its gonna be more in depth.im gonna post pics
Old May 27, 2007 | 08:11 AM
john4wd's Avatar
Oh that's right on the harness, I was thinking of another vehicle I did a long time ago...Both sides just unplug from everything and wires pull through the big hole on each side...I had a brain fart...I hope nobody read that and cut them...Oppps my bad...
John...
88sasturbotoy
Jan 30, 2026 01:57 PM
lectric80
Jul 29, 2015 12:25 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
