85 Front caliper rebuild
Old Nov 23, 2006 | 11:39 AM
PAPAGRIZZ's Avatar
While tearing down front axle on my 85 p/u to change inner seals, noticed that the right caliper is leaking around the inside pistons. How hard are the calipers to rebuild and should a kit be available at the local parts store?
Also, what has anyone done to prevent the breather on the front axle from plugging with mud? I believe this is the reason for the inner seals leaking.
TIA!!
Old Nov 23, 2006 | 11:55 AM
waskillywabbit's Avatar
Might be easier to just put on a rebuilt caliper instead of rebuilding the one you got. Local parts place can get either.
Also you might think about upgrading to vented rotors and the bigger IFS calipers for your 85 SFA while you are doing things. I have those parts on my website under "brakes".
Front differential breather mod...a search will tell you what you want to know.
Old Nov 23, 2006 | 12:49 PM
CJM's Avatar
CJM
Just change both sides, I didnt and wound up with the passenger caliper causing braking problems where the truck would pull when you braked.
Remancalipers from an auto parts store will be fine, yota OEM will be $$$$.
Old Jan 18, 2007 | 04:40 PM
gotboostedvr6's Avatar
what is needed to go with ifs fronts on a 84 solid axle?
Old Jan 18, 2007 | 05:05 PM
84 SFA to "bigger brakes" you'll need/want:
Vented rotors
"finned" IFS V6 calipers (4 big pistons instead of 2 small and 2 big like SFA) loaded
1.5" wheel spacers to clear them (on most rims)
SS braided extended brake lines
If you have any specific questions let me know as all this stuff is on my website.
Old Jan 18, 2007 | 08:30 PM
bktaco's Avatar
i found the same thing when i took the front end apart on my 85 4r - weeping from the pistons on one caliper. i went to NAPA, it was only around $45 for a reman, so i did em both.
i didn't do this, but it might be a good time to bleed the rear break lines out thoroughly (ie, full fluid replacement) before you do the whole front job (and then do them as thoroughly). just a thought.
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
scottyg486
Jul 19, 2015 05:34 PM
Vargntucson
Jul 4, 2015 12:15 PM
