85 4runner brake problem question ?
Old Feb 11, 2011 | 06:27 AM
2003mikem's Avatar
My brakes work great until Tuesday? All of a sudden it seems only the rear brakes are working, or they are working more than the front ?
Any thoughts what to check this weekend ?
Thanks mike
Oh
1985 4runner 4” lift all else is stock. Besides the tires.
also the pedal seems spungy.
Old Feb 11, 2011 | 06:38 AM
xxxtreme22r's Avatar
Master cylinder would be my guess. Upgrade to a 1" master and maybe a dual diaphragm booster from a v6 truck. Does not have to be from a v6 truck though, but when looking for parts at a parts store, it's just makes it easier. I have a master from a t-100 in mine. Cheap at autozone new and comes with the reservoir. Although the 1" AISIN master are the best to use.
Old Feb 11, 2011 | 06:49 AM
2003mikem's Avatar
please explain Upgrade to a 1" ?
Old Feb 11, 2011 | 06:53 AM
waskillywabbit's Avatar
Aisin 1" bore
Old Feb 11, 2011 | 07:02 AM
all you need to know about a booster and master upgrade:
http://home.4x4wire.com/erik/4runner/brakes/
Old Feb 11, 2011 | 08:27 AM
Outsane's Avatar
any brake fluid leaks?
did the pedal fall to the floor?
Bleed the brakes, or just throw parts at it
Old Feb 11, 2011 | 08:33 AM
2003mikem's Avatar
No leaks, pedal does not go to the floor
Old Feb 11, 2011 | 08:45 AM
Outsane's Avatar
any difference if you pump the brakes?
no leaks the prop valve, LPSV...
Old Feb 11, 2011 | 08:56 AM
2003mikem's Avatar
nope no leaks. if i pump it the back lock up faster?
Old Feb 11, 2011 | 09:10 AM
Outsane's Avatar
no, but if your losing pressure from a bad MC pumping the brakes can help..
GreenLion
Jun 7, 2021 10:49 AM
gillesdetrail
Nov 19, 2019 12:56 PM
Aleeex_u
Jun 5, 2016 06:52 PM
ItsAtoyotaLIFE
Jun 21, 2015 11:45 AM
