85 4rnr 4.3 swap pics
Old Feb 6, 2009 | 06:10 PM
texcat101's Avatar
I have been working on this swap for a while and some of you have seen the thread. '98 4.3 vortec with a multiport mercruiser intake, megasquirt II stand alone ignition and fuel controller with an EDIS 6 distributorless ignition.
700r4 tranny, toyota gear drive transfer case.
https://www.yotatech.com/forums/f163...l#post51051730
Its finally starting to take shape so I wanted to post up these pics...
Old Feb 6, 2009 | 06:17 PM
904_runner's Avatar
Nice!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 6, 2009 | 06:35 PM
algranger's Avatar
nice! looks like it's fitting in there perty nicely
Old Feb 6, 2009 | 07:30 PM
taconasty's Avatar
whats the significance for the marine intake? i think most marine stuff has larger water ports but is there any other reason?
Old Feb 6, 2009 | 07:41 PM
bigarms23's Avatar
nice conversion it inspired me to put a 4.3 in my 884runner and ditch the 3.0 thanks
Old Feb 6, 2009 | 07:55 PM
algranger's Avatar
is that a brake master cylinder from a newer 4runner?
Old Feb 7, 2009 | 03:40 PM
texcat101's Avatar
Split rail multiport - it has 6- 24 lb. bosch injectors(rated 220 hp) instead of the central port injection ( rated 190 hp), larger/more open ventura,stepper iac valve, and a nifty vacuum operated fuel regulator... I couldn't resist.
Old Feb 7, 2009 | 03:52 PM
texcat101's Avatar
That's good to hear. You helped me several times when I was a newb.
I am very close to having it all wired and have an appointment tuesday to install the exhaust... so close I can taste it!
Old Feb 7, 2009 | 03:55 PM
texcat101's Avatar
Yes from a '94 4runner, bolted right up and now combined with the landcruiser rotors and '94 4runner calipers -she stops on a dime!
Old Feb 14, 2009 | 02:04 PM
texcat101's Avatar
It's alive!
Old Feb 15, 2009 | 05:03 PM
bigarms23's Avatar
sounds great what exhaust are you going to put on it
Old Feb 15, 2009 | 06:35 PM
texcat101's Avatar
It's 2.25" from the collectors to the crossover and 2.5" from there on back thru a flomax, It sounds much better in person.
Old Feb 15, 2009 | 08:26 PM
live4soccer7's Avatar
nice swap! Very clean looking and it sounds great too! I'm looking for something to swap into my 84 4runner.
Old Feb 15, 2009 | 08:29 PM
904_runner's Avatar
How does it drive???????????????????????????
Old Feb 16, 2009 | 06:06 AM
texcat101's Avatar
I wired up the torque converter lockup and neutral/park safety switch yesterday and found the correct wires to wire the alternator, so after some tuning tomorrow morning I will hit the road.
I still have the 5.29's in it (I have the original 4.30's to reinstall) and the idle is set too high, when I put it in gear it chirped the tires.. It just feels like it wants to go!
Old Feb 16, 2009 | 07:41 AM
mikepr55's Avatar
I have been thinking of this same swap for my own rig a 84 with carb of course but my budget limited me to a lift and gears with some 32x11.50 BFG a/t s on eagle alloy wheels tires had 90% tread got those for 450. Yours looks geat i am very glad yours is working out so well. If you don't mind me asking how mutch you got into it with the transplant and all. send me a pm if you like
Old Feb 16, 2009 | 11:54 AM
texcat101's Avatar
You could do the basic swap for under 3K but I have at least 5K in this one.
But I totally overhauled the engine, .30 over pistons, rebuilt tranny, 2" body lift, tuned port injection,new starter,new alternator, megasquirt....
If you started with a good complete donor for the 4.3 and tranny, already had the gear drive t'case in your rig the other parts would be:
AA adapter kit with headers and motor mounts $800
Body lift with new bushings $180
Radiator $200
exhaust work $300
misc. hoses, fittings, belts, intake... $500
Driveline work $300
Total $2280
icentropy
Sep 16, 2020 02:47 PM
keithporter83
Jul 24, 2015 07:37 AM
94whiterunner
Jul 12, 2015 07:15 PM
jon.r
Jul 11, 2015 03:34 PM
toyoda8488
Jul 5, 2015 10:18 PM
