85 22re gettin hot
85 22re gettin hot
pick up a 85 4x4 22re yesterday, took a while to find a straight axle 22re truck around here in Kentucky. Took her out today on the trail and overheated. it was pretty hot here today about 98 so I thought well maybe the tstat was stuck so i took the neck off and no tstat was found. no coolant in oil, water pump good, coolant level is fine. Let it set for a hour started it up let it idle for 15 20 mins and the temp was fine got back on the trail and she heated back up? does not having a tstat make a truck overheat? Any suggestions woud be help full. thank you much
It can, the t-stat regulates the temperature by controlling the coolant flow through the radiator. If you get too much flow through the radiator, the coolant can move fast enough to not have enough time to transfer any heat to the air. Try putting in a proper t-stat:
- http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
and also check inside the radiator to see if the cooling passages are open or plugged.
the1998sr5
15
Jul 14, 2020 08:35 PM
Dennisx2
Aug 4, 2015 01:26 PM
the1998sr5
Jul 16, 2015 06:20 AM
