85 22re blowin black smoke
Old Aug 3, 2008 | 05:27 AM
1st84runner26's Avatar
my truck is blowin black smoke when i rev it up, smokes like a diesel, also it blows white blue smoke, but not has bad has the black smoke. My guess is runnin to rich, this is my first fuel injected toyota. where do I start to fix the black smoke. any opinons would be helpful
Old Aug 3, 2008 | 06:31 AM
HOOKED's Avatar
It could be the coolant or 02 sensor but I would also look at the
cold-start injector and time switch for proper operation. It appears
that the engine is running too rich. Have you checked for codes yet. Is
the air filter element in good shape or is it filled with crud?
Old Aug 3, 2008 | 04:00 PM
84sr5yoty's Avatar
Chances are it's either the coolant temp sensor or the AFM is malfunctioning. Also check fuel pressure regulator. When the diaphragm goes bad, it'll piss fuel out of the vacuum hose nipple at idle.
steve miller
Oct 10, 2015 01:40 AM
o2raybid
Sep 4, 2015 12:45 PM
Jonny246
Jul 24, 2015 12:37 PM
Nickdigg
Jul 7, 2015 06:04 AM
