84 Solid Axle rebuild..w/pictures :)
Old Apr 25, 2009 | 08:57 PM
toyospearo's Avatar
use the search or google
here is a start
http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
http://www.birfield.com/~morgan/tech/axle/index.html
Old Apr 25, 2009 | 09:14 PM
kcpanages's Avatar
so let me get this right........... the cone washers are on the top of the stud holding the plate/steering arm in place? so there is 8 of them. 4 on top 4 on the bottom? or just one on top and one on bottom? sorry for so many questions. im an ol chevy guy. this is my first yota SA. what a differance it is between the trucks
Old Apr 25, 2009 | 09:34 PM
BLKNBLU's Avatar
Originally Posted by kcpanages
where can i find the FSM? what is the deal with the cone washer
Here is one I have posted before
http://www.functionalfab.com/resourc...%204runner.pdf
and here is a sticky I just recently found myself with lots of great links including the one I have above. It puts us all just a couple clicks away from fantastic help.
https://www.yotatech.com/forums/f120...s-info-175794/
On the cone washers, yes, 8 on the knuckles. There are also 6 smaller ones (per side) on the locking/freewheeling hub. I've had good luck getting them out by using a brass drift on the studs that the washers are placed on. Like one of these
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
The brass being softer than the stud, you won't damage the stud, but the cone washers generally pop loose with a couple solid taps. Once in a while you get a stubborn one.
Old Apr 25, 2009 | 09:46 PM
BLKNBLU's Avatar
Knuckle cones under those nuts, top and bottom
Hub cones under those nuts
Old Apr 25, 2009 | 11:01 PM
  #25
kcpanages's Avatar
thanks guys. yall have been a big help. i recon wabfab will be getting an order from me tuesday, and ill be changing my axle assem and rebuilding the knuckle when i get home from puerto rico in a week or so. thanks again
Old Apr 26, 2009 | 07:46 AM
  #26
toyospearo's Avatar
Yes, There are 8 total. 4 on the passenger side top and 4 on the driver side top. There are no cone washers on the bottom of the knuckle arm.
The difference between the trucks is one is a nightmare and the other is a truck!
I own an International (not too different than a Chevy) and it is a nightmare to work on.
Old Apr 26, 2009 | 07:59 AM
  #27
BLKNBLU's Avatar
Originally Posted by BLKNBLU
On the cone washers, yes, 8 per side on the knuckles. There are also 6 smaller ones (per side) on the locking/freewheeling hub. I've had good luck getting them out by using a brass drift on the studs that the washers are placed on.
Not sure what I was thinking. Toyo is right. I'll go edit my post now, lest it throw someone else off.
Old May 11, 2009 | 04:51 AM
  #28
kcpanages's Avatar
Thank you to the OP and the other fella's that have helped this thread. i got my front left axle assemly changed with no problems. took me about 2 hours to break the knuckle down, rebuild it and put a new axle in. The problem i found was the birf cup was shattered into 3 pieces, but got it done. Thanks again
Old Feb 26, 2010 | 09:00 PM
  #29
toyospearo's Avatar
nice!!
I am about to do another full knuckle rebuild with wheel bearings.
Old Feb 26, 2010 | 09:26 PM
  #30
Teuf's Avatar
I have n axle I am going to fresh'n up. Thanks for this post...
Old Feb 26, 2010 | 09:31 PM
  #31
toyospearo's Avatar
that one looks like it needs some freshness!!
Post up some pics of the progress
Old Feb 26, 2010 | 09:39 PM
  #32
Teuf's Avatar
I will, I got that axle from a neighbor for free, his farm burned down, 1996< and his 85 woods beater was kinda toasted, so in 2001 he gave it to me, been hangin around since. That was the last thing I put aboard this boat, moving to Ca. I'll take a million pics though. Thanks
Old Feb 26, 2010 | 09:52 PM
  #33
toyospearo's Avatar
from that photo it looks like it is in pretty good condition.
Old Nov 9, 2010 | 05:40 AM
  #34
LifterCatcher's Avatar
Toyo & Others,
Thanks so much for this great thread I just picked up two 85 SA's and will be rebuilding one or both excited to get started and this thread is already helping me understand things.
Thanks
Catcher
Old Nov 9, 2010 | 07:15 AM
  #35
toyospearo's Avatar
Originally Posted by LifterCatcher
Toyo & Others,
Thanks
Catcher
No problem... take pictures!
Old Nov 9, 2010 | 07:30 AM
  #36
Outsane's Avatar
its easier then it looks !
I put it off for a long time, to make sure I would have enough time to complete the rebuild before I would need the rig. I should have done it sooner.
Old Nov 9, 2010 | 09:27 AM
  #37
SCToy's Avatar
May I ask where you found a hub rebuild kit? My 81 has a malfunctioning hub. I guess it may just need the little spring and ball, but I haven't taken it apart yet to look. I'll have to do that when I rebuild the axle. I did just discover I had this laying around though
Old Nov 9, 2010 | 10:21 AM
  #38
toyospearo's Avatar
Wabfab has that spring and ball. I would replace that if you get it apart. Makes turning that hub much more easy!
Old Nov 9, 2010 | 11:12 AM
  #39
Outsane's Avatar
spring and ball?
I found a spring in all the grease, I thought it wasn't supposed to be there..
Old Nov 9, 2010 | 05:52 PM
  #40
toyospearo's Avatar
Originally Posted by Outsane
spring and ball?
ahhahaha!
dude you need a new spring and ball!
