84 22R + MSD = high idle?
Old Aug 9, 2007 | 07:40 PM
RallyRoach's Avatar
1984 4runner with 22r carb motor. Installed an MSD 6-AL and a new coil on my truck tonite. Now, I can't seem to get the idle settled down, very high. Otherwise, truck is running good, smoother and no more backfires. All vaccum lines are correct, carb was rebuilt less than 2000km ago.
I reset the idle mixture to the stock 3.5 turns out. Tried turning the idle speed screw all the way in too, no effect. Still idling very high. Best guess is 2500-3000 range, but no tach anymore because of the MSD. With the stock ignition, it was idling at 900-1000 comfortably.
Open to suggestions here, but I'm guessing I'm not adjusting something right. Be nice to get it sorted out for the run on Saturday.
RallyRoach
Old Aug 9, 2007 | 08:23 PM
myyota's Avatar
You turn the idle screw on the carb out (counter clockwise) to lower the idle, also check your timing, if its advanced to far it will cause a high idle.
Old Aug 10, 2007 | 07:18 PM
RallyRoach's Avatar
Thanks for the info, got it all fixed. The timing was waaaaay out. sticky throttle cable too. Running good now, so I'm hitting teh trails tomorow. I'l post some pix and a trail report if anyone is considering the swap.
RallyRoach
Old Aug 13, 2007 | 04:58 PM
XtraSlow_XtraCab's Avatar
No tach? You should be able to hook one up to the - post of the coil. Or if its designed after the stock coil, there should be a pre-arranged plug.
dumpster84
Apr 30, 2016 06:03 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
kcaudill
Jul 20, 2015 12:06 PM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
