84 22r head gasket keeps failing cyl#2
Old Jun 8, 2017 | 09:17 PM
mattsweet's Avatar
Have a 84 22r which in last year have lost 2 head gaskets. head tested fine, had a valve job done on it last time was off. shop said it was fine and that it no need to be milled. also said it was already at min specs and to use the thicker gasket. temp never gets above 165, but it has failed once and is starting to fail again on the exhaust side of cyl 2. any thoughts?
Old Jun 8, 2017 | 09:35 PM
millball's Avatar
Block corroded, not flat??
Have you used slipperplate type head gaskets?? What brand??
If so, maybe try an Ishino-Stone plain gasket without slipperplate.
Old Sep 13, 2017 | 02:50 PM
Nathan Winslett's Avatar
Should flatten both the block and head to assure proper sealing.
Old Sep 14, 2017 | 07:43 AM
gsp4life's Avatar
Could be a hairline crack in the block or head. I'd get a HF leak down tester and then test with uv dye.
Old Sep 14, 2017 | 11:01 AM
wyoming9's Avatar
Red face
Torquing to the correct Torque ??
65 Foot Pounds .
Not torquing in the proper sequence .
Damaged threads female or male causing false readings
Old Sep 17, 2017 | 08:07 AM
gsp4life's Avatar
Any dirt, rust or metal shavings in the threads? They should be so clean that you can thread new bolts in and out easily by hand.
greyheadedguy
May 9, 2019 09:12 PM
stranded1980
17
Jul 8, 2018 07:10 PM
Yota headach
Apr 28, 2017 07:12 PM
EvenTide
Apr 10, 2017 09:35 AM
Hungrynomad
Mar 26, 2017 11:56 AM
