45 MPH vibration
Old May 16, 2009 | 12:53 PM
Alter Ego's Avatar
45 MPH vibration
i have an 84 single cab 22r, 4x4, at highway speeds, ie 60 and above ride is smooth and nice, but from 45 to 55 there is a rough vibration in the truck.
anyone know what might be causing this? i have already changed rear u joints, possibility of it being tires or front u joints? would be nice as this is my daily driver. even though i only drive 3/4 mile to work everyday.
thanks.
Old May 16, 2009 | 12:58 PM
brownbagg's Avatar
front wheels out of balance, it will be something that turns, like wheels, brake disc. you proberly have mud on your rims
Old May 16, 2009 | 01:54 PM
abecedarian's Avatar
sounds like a wheel problem, either out-of-balance or out-of-round.
try rotating the wheels and see if the vibration 'moves' with the tires.
you might be able to get them rebalanced, or try one of the dynamic balancers or the 'air-soft bb' trick.
Old May 16, 2009 | 02:54 PM
IngSoc's Avatar
Bad ujoints, Driveshaft isnt put back together ballanced (the H joints should be facing same direction) Bad alignment, Check all your stearing knickles n stuff see if there torqed down. Just prolly not the last part but good to check any ways. Just got rid of all my wobbles and humms.
Old May 17, 2009 | 11:55 AM
85RunnerSR5's Avatar
Did you mark your driveshaft when you pulled it out? It is really important that it goes in the same way it came out, or else you will have issues like what you are having.
Old May 17, 2009 | 07:37 PM
Alter Ego's Avatar
yup, marked to return the same as came out. had this vibration before, and changed rear u joints. and returned the same way. but vibration didn't cease, just stayed the same, actually the speed range has decreased since i changed them, so i figure the fronts are bad, or the tires are really out of balance. worried a bearing is out in tranny or xfer case.
Old May 17, 2009 | 08:56 PM
bigarms23's Avatar
did you have the driveshaft rebalanced or its the tire outta whack thing
Flightguy
Oct 2, 2015 05:34 PM
kbpickens
Oct 2, 2015 03:37 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
