4-runner not running on all cyl.
Old Jan 26, 2012 | 07:10 PM
reubenhayden's Avatar
92 4- runner not running on all cyl. Swapped in a motor out of 88 changed all the electronics over out of the 92 and still can't get it to run have a pulse at all injectors ,cleaned all grounds looking for any ideas I have tried everything I can think of
Old Jan 26, 2012 | 07:23 PM
rokblok's Avatar
Dist cap, rotor, wires, plugs? You said you believe you have fuel, better make sure you have strong spark.
Old Jan 26, 2012 | 07:49 PM
Changed plugs,wires,cap,rotor,and igniter. Injectors are out of the 92
Old Jan 26, 2012 | 07:54 PM
rokblok's Avatar
The injectors may have a different pulse width than the older model, could be the reason they arent working. Either not opening completely, or not long enough, or staying open to long and not atomizing the fuel properly?
Old Jan 26, 2012 | 08:13 PM
I know the 88 injectors are a low impedance and the 92 are high impedance so I used the ones out of the 92 to match my ecm the only thing I didn't change was the knock sensor. Don't know if it makes a difference or not
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
cgilley
Jul 15, 2015 03:32 AM
wilbertd
Jul 6, 2015 07:39 AM
