4-runner making noise?!
Old Jul 20, 2007 | 09:11 AM
85yotalover's Avatar
Hey, we just finished putting an 84 22-re into our 87 4 runner after the original engine over-heated. Everything seems to work fine, all fluids are in, it runs like a 22-re should, no smoke or overheating. Has fuel pressure and coolant pressure. but at 50 miles per hour it starts to make a buzzing noise, and it just gets louder and louder the more you accelerate. Please help, i really need to get this up and running as gas on my chevy 2500 diesel is killing me.
Oh and one more question, do toyota transfer cases have a breather of any sort? We have notice a small leaks on the t-case but we think we might have jsut overfilled it and it is leaking out of somesort of breather. We made this judgement by puddle size.
Old Jul 20, 2007 | 09:26 AM
4Crawler's Avatar
Try to isolate the noise. Is it the same in and out of gear. Does it vary with engine RPM or road speed (try a different gear at 50+).
T-case typically vents out the shifter hole.
Old Jul 22, 2007 | 02:35 PM
We've isolated the noise. It is either the drive shaft or the rearend. It does it in and out of gear. I drove it today and it more of a noisy vibration than a buz. I thing something is out of balance. Where would the drive shaft balance weight typically be located on the rear drive shaft, if they have them? Should i try unbolting the drive shaft and rotating it 180 degrees and rebolting it down.
Old Jul 22, 2007 | 03:36 PM
4Crawler's Avatar
See:
- http://www.4crawler.com/4x4/CheapTri...FixingProblems
- http://www.4crawler.com/4x4/CheapTri....shtml#Phasing
Old Jul 22, 2007 | 03:49 PM
how could i isolate it to the transfer case? It is still possible that it might be the transfer case. The transfer case is leaky and i think it might have a bad bearing.
coleypull15
Nov 3, 2015 07:41 AM
daddio
Jul 18, 2015 10:20 AM
cgilley
Jul 15, 2015 03:32 AM
razorman8669
Jul 12, 2015 12:13 PM
wilbertd
Jul 6, 2015 07:39 AM
