22re Reprogram
Old Oct 7, 2010 | 12:55 PM
natesyota's Avatar
Exclamation 22re Reprogram
I have an 85 22re 4x4 that I'm rebuilding again (thank god for warranties) and I want to know if there's a way to reprogram the ECU to better work with the .435 lift cam I put in it...This, heavier springs and balancing are all I've done so far...HELP!
Old Oct 7, 2010 | 12:56 PM
HighLux's Avatar
Nope. You can get a stand alone engine management system....
I think the stock ecu can handle your cam.
Old Oct 8, 2010 | 08:17 PM
natesyota's Avatar
Stand alone management? I'm not familiar with that. The truck ran great with this combo before a defect in the #4 rod detonated the bottom end, but just looking to add more torque, I guess. the motor really starts to wake up around 3k rpms, but up to that it's only marginal. I've heard of JET computers, but I think those are for the engines with the diagnostic "block" rather than the 2 pin "plug" that mine has for the ECU.
Old Oct 8, 2010 | 09:54 PM
mightymouse's Avatar
look into mega squirt for the stand alone system but yeah your motor should be fine with the stock ecu.
Old Oct 9, 2010 | 01:10 AM
peow130's Avatar
Well most likely the cam you got is designed for midrange to upper range torque. So I doubt anything you do to the ecm will help with the low end torque. You should consider a header, though. After driving another 22r with a header there is definitely a lot of gains from it.
Old Oct 11, 2010 | 08:43 AM
natesyota's Avatar
ok, stock ECU...check. I'm using a pacesetter header now, with 2 1/4" all the way through a 40 series flowmaster. Should I go smaller on the exhaust to create more backpressure? or did I go too big on the cam?
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
