22re low idle, no power, backfiring
Old Apr 10, 2015 | 12:33 PM
harasyn92's Avatar
Hey guys, my truck was running perfectly until yesterday. When I parked it all was good. I started it up after sitting for a couple of hours and it was idling very low. When I started driving I noticed it was low on power. It seemed to be only running on 3 cylinders. When I let off the gas it backfires. Any suggestions? The check engine light is not on. My truck is a 1986 efi. I'm going to start with the injectors and grounds and go from there.
Cheers,
Paul
Old Apr 15, 2015 | 09:18 AM
jimbyjimb's Avatar
Popping on decel generally means you're running lean.
Old Apr 15, 2015 | 12:34 PM
snobdds's Avatar
Some how your timing got off. I would check your ignition timing (cam timing) first and then your crank timing. Your crank timing needs to be at 0* and your ignition timing needs to be at 5*.
If your timing is off, then you need to find out why it went. Probably need to inspect timing chain and tensioner.
Old Apr 15, 2015 | 03:14 PM
19954Runner's Avatar
Also try your valves
Make sure they are set back to spec
Just has the same issues on my 1988 22re pickup.
Runs like a champ again
Old Apr 15, 2015 | 03:48 PM
58rennur4's Avatar
Cheers,
Paul
How about checking stored codes first?
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
bryan34w
Jul 6, 2015 05:53 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
