22re. IS loose idle screw common?
Old Sep 29, 2008 | 01:15 PM
DanStew's Avatar
After putting a mark on my idle screw, I have found out that it is turning on its own and dropping my idle, hence why my engine idles rough after a while. I am going to add a drop of RTV to keep it from moving again. I am curious to know if this is a common problem for the 22re fuel injection, and is it something more that i need to look into?
Old Sep 29, 2008 | 04:07 PM
bigarms23's Avatar
no its not common it sounds like its time to replace the screw
Old Oct 1, 2008 | 12:31 AM
pcmentor's Avatar
There may be an o-ring on the screw you can replace.
Old Oct 1, 2008 | 12:52 AM
XtraSlow_XtraCab's Avatar
Or a spring? On carbs anyway, adjusting screws (like an idle screw) have a coil spring rapped around the threads. I assume it keeps tension to reduce self-spinnage.
Old Oct 1, 2008 | 04:33 AM
bipolarandproud's Avatar
Yup , I'm guessing it's from vibration .
Blamalam
Mar 12, 2022 07:34 AM
_Nicco_
Aug 28, 2015 07:26 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
sojourner567
Jul 16, 2015 08:52 PM
