22re issue
Old Jul 18, 2010 | 12:33 PM
mikev89's Avatar
22re issue
my truck has been a DREAM and an over 1k mile road tripper until yesterday the truck started right up with the usual little bit of smoke right away but started up real loud and idled unusually high at about 2k for a bit,
i parked at taco hell and after it refused to turn over, and giving it gas did nothing ,and when it does it missfires spudders and shudders real bad for about a minute
eventually it will idle fine and run okay
today i was driving engine bogged out when i tried to give it gas,
and when i gave it gas rpms dropped and truck nearly stalled but never did, if i released throttle and push the clutch the truck will idle normally, and rev seemingly normally, i some how "unbogged it" by revving the engine in neutral and giving it gas the truck seemed to fix it self for the time being and drive okay
i just replaced the spark plugs today it helped the startup a little, i dont know where to start, MAF? fuel pump? valve seals? rings? thanks
Old Jul 18, 2010 | 12:39 PM
myyota's Avatar
Replace the fuel filter if it hasn`t been done in a while, and see if that helps, also check the TPS, that can also cause the problem your having.
Old Jul 18, 2010 | 12:52 PM
mikev89's Avatar
oh yeah, truck sometimes lets out bluish white/white or kinda light blueish smoke (it does burn oil)
Old Jul 18, 2010 | 01:08 PM
myyota's Avatar
That could be caused by bad valve guide seals.
Old Jul 18, 2010 | 02:30 PM
mikev89's Avatar
well ..now its not even turning over and starting up
Old Jul 18, 2010 | 05:06 PM
myyota's Avatar
Is it completely dead or will it turn over but not start ?.
Old Jul 19, 2010 | 06:47 AM
mikev89's Avatar
it will turn over, but not start. my mistake.
before the truck took a i would hear a weird humming coming from the front of the engine bay. i bet the fuel pump took a
Old Jul 19, 2010 | 07:06 AM
Fink's Avatar
Missing a few words there, huh?
Sounds like fuel pump to me as well.
I'd replace that and do a full tune-up on it (if it hasn't been done recently).
Mainly fuel filter, plugs and the usual cleanings (TB and such).
Fink
Old Jul 19, 2010 | 07:24 AM
xxxtreme22r's Avatar
check the fuse and pump relay first. You may have just heated up the pump leading you to blow the fuse/relay.
bigjstang
Jun 2, 2025 03:56 PM
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
montanatruck
Feb 26, 2017 07:07 AM
PlayAwhile
Jul 20, 2015 11:36 AM
