22RE Harmonic Balancer
Old Jun 10, 2009 | 07:08 AM
85 FF / medic's Avatar
OK..... I need to replace the Harmonic Balancer on my 85 22RE. IS there anything as far as tricks and sleves or gasket I will need that you guys can help with? Also is the Fuel filter as much of a bitch as it looks? Thanks
BJ
Old Jun 10, 2009 | 08:12 PM
taconasty's Avatar
actually the fuel filter is easy, there is an access panel in the pass side wheel well. easy. the crank bolt can be loosened easily by putting a breaker bar or good 1/2 drive ratchet on and laying it on the steering box. putt it on the bolt and have it lay on that side. this may not be coming out as clear as i am thinking. and the just jog the starter, dont start it. works like a charm.
Old Jun 11, 2009 | 04:10 PM
Nice....... Is there any kind of gasket or sleve i have to replace after removing the balancer? and do you know the torque specs when reinstalling the new one?
Thanks
BJ
Old Jun 12, 2009 | 08:02 AM
taconasty's Avatar
Thanks
BJ
yes there is. i would replace that seal, it usually leaks oil. and the torque specs are something like 125 not sure. i always hate it when people just tellyou to search but you could have found this info like i did by searching. there is an article about replacing your timing chain that will have the torque specs.
Old Jun 13, 2009 | 12:12 AM
pcmentor's Avatar
1985 22re FSM Page EM-45
(b) Torque the pulley center bolt.
Torque: 1,600 kg-cm (116 ft-lb, 157 Nm)
Old Apr 23, 2015 | 09:37 PM
deesmckee_ak's Avatar
116 ft/lbs.
Old Apr 24, 2015 | 09:07 AM
pcmentor's Avatar
I filled #1 cylinder with rope, stuff it in, to loosen and tighten crank bolt. Put on TDC and back it off a little each way on and off. Stuff with rope and it holds the crank to torque it. Pete
Jcrawl94
10
Oct 24, 2015 04:34 PM
romex1
Aug 10, 2015 06:21 PM
dropzone
Jul 16, 2015 02:00 PM
