22re Ecu
Old Dec 26, 2008 | 02:55 PM
Motomeister's Avatar
22re Ecu
Looks to me that my 85 didn't originally have a 22re in it but they swapped one in. I have a fault code that traced to the TPS. Started looking at it and made sure the ecu had wiring to it from it. The two pins where the ecu should be talking to the tps arent even pins. On the ecu it says 22R so does that mean its going to take a lot of work for the ecu to talk to the TPS?
Old Dec 27, 2008 | 01:27 AM
Wardamneagle's Avatar
Here are the ECU numbers courtesy of 4Crawler's website:
http://www.4crawler.com/4x4/Images/22RE-ECU-Table.gif
I have used the original ECU (89661-35020) and an '86 ECU (89661-35070) in my '85 4Runner and both work.
These come up on ebay quite often or you can get one from a breaker yard. I would start by comparing the wiring diagrams for the truck and 4Runner and try to see what harness you have installed. If you have an RE harness and all the wires are connected to the TPS, then you might get lucky and can just plug one of these ECU's in and it will work.
Good Luck.
Old Dec 27, 2008 | 08:25 AM
ecu is a re ecu it looks like, but my harness doesnt have the pins for the TPS. What do i gotta do now, get a new harness?
Old Dec 27, 2008 | 11:28 AM
I looked at the diagram wrong, my wiring harness is all correct. Disregard this thread
Old Jan 3, 2009 | 06:36 PM
tomeez toy's Avatar
I have a 1989 22re. My truck sputters at 15mph, I cant seem to drive 15mph at a school zone without my truck sputtering and jerking crazy. I conducted a diagnostic test and got a #12 (a/c, distributor) and a #51 (TPS) reading. any one familiar? where do i start?
RatOmeter
Oct 22, 2015 03:17 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
dfarr67
Jul 30, 2015 07:08 AM
Daneums
Jul 28, 2015 11:57 AM
Sandman
Jul 14, 2015 12:36 PM
