22re check engine light off and on o2 sensor question
Old Jun 15, 2009 | 10:10 AM
willia12's Avatar
I have an 85 pickup with the 22re, after market headers, new after market o2 sensor and a good cat (just had it checked). When I drive on the freeway at sustained rpms for about 5 mins the check engine light will come on. The light will stay on until I take my foot off of the gas, it then goes off and comes right back on again 5 mins later. I had a couple exhaust leaks that I thought were causing the problem; well I just had them all fixed and now the light does not come on as often, but it still comes on sometimes.
I've been told that some times just having an after market o2 sensor can make the light trip. Is that legit? Has anyone ever come across a problem like this?
Also, the truck is not having any drivability issues (my mechanic friend says it's running great
Old Jun 15, 2009 | 08:21 PM
desertcamper67's Avatar
You need to jump the diagnostic plug and see which code its showing then go to the list 4Crawler has and see what your code means.
I have always used aftermarket O2 sensors and never had a code from them. Usually used Bosch.
Old Jun 17, 2009 | 07:19 AM
willia12's Avatar
Cool. Thanks I'll try that and post back.
AudiKev
Sep 3, 2019 02:55 PM
digdug40
Aug 28, 2015 02:24 PM
raptor510
Aug 19, 2015 02:15 PM
Koolbananass
Aug 12, 2015 01:59 AM
