1985 Toyota truck keeps blowing 80amp fuse.
Old Sep 24, 2022 | 02:54 PM
RustyFrames's Avatar
I have been playing with these trucks since 1985 and have never ran into an issue like this. I put a new carb on the truck like I have before and then the 80 Amp fuse started blowing. The only wires that I moved was the plug when I unplugged it and plugged it back in. I was happy it started and ran though. Right off the bat I replaced the ignition switch since it was the original. I then unhooked the starter, Alternator and carb plug. Turned the key and poof there goes the fuse. Looked deeper and found a wire that was rubbing at the fuse box. Repaired it, left everything else as it was. Turned key switch and then poof went another 80 amp fuse. All the ground straps have been checked and verified for proper connections. I am at a loss. Any ideas??[QUOTE]
Old Oct 31, 2022 | 05:18 PM
UPDATE: The issue was a short within an electrical component of the new carb.
RustyFrames
Nov 6, 2022 02:19 PM
cskeegan8
Jun 18, 2020 11:55 PM
deepthinker22
Apr 11, 2019 04:38 PM
ozziesironmanoffroad
Sep 30, 2008 09:06 PM
