1985 4Runner. No start
Truck is a 1985 4Runner 4x4 22re 5-speed.
The truck recently started to have this issue where it would turn over then sputter out within seconds. The starter turned over the engine without any trouble (strong start). I can hear the fuel pump running when I turn the key.
The very next day I go in to the garage to try and see if I can figure out what's wrong, but now it won't start at all! It was as if the starter was no longer connected.
Using a volt meter, I got 12volts at the battery and at the ground the battery is wired to. (Battery and alternator replaced within 2 months)
Could it be a fuse? Maybe a bad ground somewhere else? Any help is appreciated.
I checked and cleaned all of the fuses and the engine grounds in this very helpful thread https://www.yotatech.com/forums/f116/22re-ground-wire-locations-guide-194413/
I ran a 10awg wire from the negative battery terminal to the ac compressor bracket (good ground checked with a volt meter) as I didn't have this engine ground listed in the thread above. STILL no start but I left the wire in place for the rest of the time as it wasn't hurting anything.
Checking with a volt meter on the starter solenoid plug while my friend turned the key to start the engine showed that I only had about 6 volts going to it. I ran a direct jumper wire to the solenoid from the positive terminal on the battery and finally, I got the engine to turn over. the starter now ran with the key in the ignition almost like the starter needed a wake up. But still the engine would die after just a few seconds.
Then I ran a direct jumper wire to the fuel pump while my buddy turned the key in the ignition. Fuel pump was running great, but still the same sputter out within a few seconds.
After that I used an ohms meter to test along the AFM prongs http://4crawler.com/4x4/CheapTricks/AFM/index.shtml#AFMtesting everything check out ok!
I finally got so impatient, I took the intake tubing off, pinned the throttle body open with a screw driver, direct jumper to the fuel pump, while my buddy turned the key. Still! Just a start then a high rev followed by a run for 3 seconds.
The spark plugs, cap, and rotor have been replaced within a month. Tomorrow I plan on running the fuel pump past the fuel filter in to a bucket to see if the fuel is good. I just need some suggestions or and advice. Thanks!
jtsefton
Feb 3, 2016 07:33 PM
