1985 22r - where do these 2 vac lines go? (pics)
Old Jul 23, 2011 | 08:33 AM
6th Gear's Avatar
I just got my newer motor (86 22r) installed in my 85 and for the life of me, can't figure out these two vac lines...
First one:
I don't even know what this sensor is, couldn't find it in the FSM. has a #1 on the line, about ~12" long
Second one:
bottom edge of the air box. Had a ~6" line on it, so I know it wasn't the line in the first pic.
Old Jul 23, 2011 | 11:43 AM
6th Gear's Avatar
Ok, I figured out that the line on the bottom of the air box goes to the second line from the top on the VCV
However, I now have another vac line with no home.
It is the line right next/below the circled one in this pic:
I can't even find this sensor anywhere in the factory service manual for my 85 truck. I have stripped the 86 truck that the 22r came from but I don't see that there was ever a sensor like this on that truck.
Does anybody know what this sensor is? It has a little charcoal filter one one side and 2 vac lines on the other side. I need to know where those 2 lines go.
There's a 2-wire plug going into the sensor with a blue and a back/red wire.
Hopefully this truck will be starting today!
Old Jul 23, 2011 | 02:05 PM
6th Gear's Avatar
looked again at pics I took before I toook it part and figured out that this sensor ran inline between the vcv and asv. got everything hooked up nw, but still wont start. if I pour gas in carb, it will fire up and run if I keep giving it gas. I'm about to give up for today....
Old Jul 23, 2011 | 06:46 PM
ROCK LIZARD's Avatar
The valve in your first image is the VSV (vacuum switching valve ND 084600-3310 ). If you have a/c, the line closest to the valve body connects to an idle-up actuator on your carb, the other line attached to the L-fitting connects to a hex-shaped fitting on the intake manifold under your carb.
If you don't have a/c, check out this link for diagrams--http://www.pirate4x4.com/forum/showthread.php?t=579557
The vacuum line coming off your air filter housing connects to a sensor valve attached to the thermostat housing. The valve has two fittings, your vacuum line from air filter box connects to fitting closest to thermostat housing.
Hope this helps
Old Jul 25, 2011 | 12:21 PM
6th Gear's Avatar
I got all the lines and it still wasn't starting unless I poured a little gas in the carb and then it would die if I didn't keep giving it gas. Float level was good. So I put the choke from my 85 on the 86 motor and it was the same thing. So I put the 85 choke back on the old motor took the entire carb off and put it on the 86 motor and it fired right up!
Old Jul 25, 2011 | 03:06 PM
Good job!
Liadrin
Apr 25, 2022 02:54 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
Liadrin
Sep 1, 2015 06:44 AM
bryan34w
Jul 6, 2015 05:53 PM
